-   -   Insulation in walls and ceiling (http://www.skoolie.net/forums/f13/insulation-in-walls-and-ceiling-25956.html)
Pizote 02-21-2019 07:28 PM
So... I started pulling the walls today and found the following:
* 2Ē of fiberglass insulation in the walls. All good condition.
* to get the walls off, in need to either:
A) pull the windows
B) cut the walls off just under the windows.
So here are my questions:
I get that closed cell insulation is better than fiberglass. But whatís the ROI on pulling everything out to remove so-so R-factor and replace it with slightly better? I prefer to insulate vs sound and temperature but it seems this is a high cost to get there both in time and money.
As for the windows, I like the look of them and will be sealing them where they will just provide light and not open. Followed up with insulation when needed. Seems like a lot of effort to remove the windows just to put them back in. They donít leak so thereís that.
As for cutting the walls off, I can do that quickly, not an issue but at this point... why?
The ceiling will come down. Itís all screws anyway. So thatís not a concern. I will replace that insulation.
o1marc 02-21-2019 08:02 PM
The insulation in a bus is minimal, it was not designed for long term use during the day. The wall metal you will probably find is spot welded just under the window lip, so removing the window doesn't really gain you anything. Most of us cut that panel off just below the window line so better thicker insulation can be added in those cavities. I bought a $50 set of electric shears from HF, makes quick work of that metal and any other I'm using in the build.
EastCoastCB 02-21-2019 08:33 PM
I wouldn't call foam "slightly" better but to each their own.
I'm not planning on pulling the metal out of my shorty. Its just gonna be a weekend cruiser.
Pizote 02-21-2019 08:36 PM
Me calling it slightly better is my lack of knowledge. In the few minutes since I posted Iíve removed one ceiling section and the insulation there is pretty poor quality as has been indicated.
Iíll cut the wall panels out this weeding. It would be a good use of my plasma cutter ;)
o1marc 02-21-2019 08:52 PM
Mines not working or that would have been my go to tool.:thumb:. Woulda come in handy cutting in my RV windows. Gotta get that thing fixed.
mrpincher 02-21-2019 09:46 PM
R15 is much better
I'm slowly working on my bus and am past the insulation stage - so I can comment. It has been a rather strange winter in Amarillo this year. We've had short bursts of teens and 20 degree temps, always with lots of wind. This "winter" weather has given me a chance to sample the "environment" in the unaltered bus, the stripped bare bus, finally the insulated bus. I have R10 in the floors, R15 in the lower walls, R10 in the ceiling and upper walls. Major difference in the condensation; I now have zero condensation except around the front windshield and half dozen remaining windows. The bus is much easier to keep warm ( and should be easier to keep cool in summer). I'm able to turn the heater off much earlier in the day when it's really cold out. I wouldn't add more insulation - but I wouldn't remove any either. It wasn't cheap, I'd do it again.
Mike
Native 02-21-2019 11:40 PM
Mr Pincher, what products and thicknesses did you use?
Ciscokid 02-22-2019 06:08 AM
1 Attachment(s)
You will regret not pulling them windows out and sealing them in. This is easily seen with a laser temp gun you can get a wal mart or home depot. Insulation is priceless in a bus. If you splurge on anything I would insulate the best you can. These things are like toaster ovens in the summer and a meat locker in the winter. We have over done it with the ceiling and walls but sure wish I would have done more on the floor. The air goes right under the bus and makes it very cold.
mrpincher 02-22-2019 07:13 AM
Insulation
OK. I don't have a smart phone, pictures are on my camera...still.
Regarding insulation, I took the advice of our senior members on this forum and am glad I did. The condensation in my smallish 22 foot interior space was really bugging me :banghead:. No longer the issue it was. My lower wall cavities measure 3 1/4 inches deep. They're filled with 3" of the Pink Owens Corning foam board from home depot. According to the manufacturer that = R15. I have the foam board glued tightly to the exterior metal. Mucho adhesives have been purchased throughout this build.
On the ceiling and above the windows I used the two part spray foam. Purchased on ebay and applied it without any hiccups. My job didn't exactly look as good as some of the professionals that I've seen on this forum. Its horrid stuff to apply. But I got the depth of insulation build up enough to fill the ribs of the bus + 5/8" = total of about 2 1/4 inches on the ceiling.
The floors have a 2" slabs of the pink foam board with 5/8" subfloor over that.
There's still condensation on the remaining side windows and on the windshield. I plan to monitor that as needed and plan to use the high tech "wipe it up" with a rag method to control that small amount of dampness.
Mike
Ciscokid 02-22-2019 07:19 AM
Are you using Propane to heat? It causes condensation very bad and not really any way to get around that with single plane windows. Dry heat will keep your bus from rusting and save you from chances of mold growing in hide away places.
