-   -   Emergency exit interlock bypass (http://www.skoolie.net/forums/f49/emergency-exit-interlock-bypass-26540.html)
robertv 04-09-2019 07:04 PM
Thanks to all of you about to post that this has been addressed adnauseam, and kindly point me in the right direction to learn how to bypass this so my bus will still start.
Thanks
o1marc 04-09-2019 07:45 PM
You have to figure out which wires to connect to make it think the door is closed. On mine, after deleting the hardware, one ground wire still had to be connected. Check one connection at a time and turn the key until you get the combo that works.
PNW_Steve 04-10-2019 11:32 AM
Knowing what bus you have would be helpful. Perhaps you could fill out your profile?
On my bus I had to remove a relay behind the dash and plug a jumper into the relay socket.
Here to learn 04-15-2019 08:04 AM
http://www.skoolie.net/forums/f49/i-...ere-14909.html
This was my saga with interlock issues, I posted wiring diagrams and user manual on page six
