-   Titles, Insurance, Registration and Money Matters (http://www.skoolie.net/forums/f18/)
-   -   Buying small bus from a school district - California (http://www.skoolie.net/forums/f18/buying-small-bus-from-a-school-district-california-28610.html)
oldnomad 09-13-2019 05:48 PM
A school district I work for in California is looking to get rid of two van chassis type school buses. They don't want to deal with the paperwork or whatever is required and want me to buy them for $1 as scrap. They currently have exempt plates.
My question is, is this doable? Will I be able to register them? Do I have to smog?
If needed I have a house in Nevada as well that I can register it to.
musigenesis 09-13-2019 06:22 PM
Here's the "whatever" they have to deal with (if the buses are 2003 or older): https://ww3.arb.ca.gov/msprog/trucks...egs/dmvreg.htm
Basically, trucks and buses that old need to be re-engined with a 2010 or newer engine, so a lot of school systems are going to be looking to dump buses. Luckily, motorhomes are exempt: https://ww3.arb.ca.gov/msprog/trucks...egs/others.htm, but you do have to report in to prevent your registration from being wrongly denied: https://ww3.arb.ca.gov/msprog/truckstop/azregs/edvr.htm
peteg59 09-13-2019 06:25 PM
Score!
Don't know CA DMV rules on your new possessions, but you could easily take them to any of the other 48 continental states to register and or unload them.
Good luck...
o1marc 09-13-2019 07:04 PM
I'll give you 5x's your money for one.:thumb:
Danjo 09-13-2019 07:29 PM
https://ww3.arb.ca.gov/msprog/truckstop/tb/truckbus.htm
Diesel trucks and buses with a Gross Vehicle Weight Rating(GVWR) that is greater than 14,001 pounds (lbs), must reduce exhaust emissions by meeting particulate matter (PM) filter requirements and upgrading to a 2010 or newer engine model year (EMY).
The Regulation applies to:
Diesel vehicles with a GVWR greater than 14,000 lbs.
Privately and federally owned trucks and buses that operate in California
Any person, business, school district, tribal reservation, or federal government agency that owns, operates, leases or rents affected vehicles.
The Regulation does not apply to:
Gasoline or dedicated natural gas vehicles
Solid Waste Collection Vehicles
Public Agency and Utility Vehicles (Not Federal)
Drayage (Port or Rail) Trucks
Transit/Urban Buses
Personal use motor homes or recreational vehicles
Danjo 09-13-2019 07:31 PM
musigenesis, I think you are wrong about this. Iíve spent a lot of time researching this and even made a call to CARB. Those cutaway buses are all less than 14001 pounds GVWR and the rules do not apply.
Danjo 09-13-2019 07:36 PM
You will have to pass smog. The test is pretty simple.
Visual tailpipe smoke test
ODB (if equipped) check for codes. Needs to be code free.
No emissions testing by machine
oldnomad 09-13-2019 07:50 PM
How about the registration process?
Danjo 09-13-2019 08:20 PM
Same as any vehicle. The title will be SB. DMV didnít care.
lqdchkn 09-16-2019 08:26 AM
What location, year, make, model?
I might be interested if you want to off load one?
