-   -   Bus Electrical Systems - AC (http://www.skoolie.net/forums/f10/bus-electrical-systems-ac-448.html)
Les Lampman 12-14-2004 10:47 PM
This is the start of the new Bus AC section
This is a modified thread and has been resurrected 10/05/16 starting on page 18
This was edited 12/5/2016
Original wording "How To" section...Under Construction! :lol:
Ryan Grimm 11-17-2005 12:41 PM
General AC Wiring (or, how I would do it)
There are a couple ways to wire the bus, and by this I mean:
Do I put the wires in the chase up by the ceiling;
Do I put them along the floor behind the cabinets;
Do I put them in conduit under the bus?
I'm probably going to do a combination of the three. Most of the main wiring I will run under the floor, going through grey PVC for the main runs from the panel to the runs that will be broken down into the individual areas.
The PVC will be firmly supported, preventing any sag or vibration from operation of the bus which would fatigue wires and cause breakage or shorts.
Any wire connections will have wires twisted together with pliers, wire nuts firmly screwed on, then further secured with colored electrical tapes.
The electrical tape colors will also be an indicator of what the circuit is for; I will be color-coding the wires so I know what goes where for future repairs and additions.
Then I will make up a wiring diagram for future reference.
At that point I will branch up/out to any outlets or switched lights, running under any convenient cabinets or up the wall in a chase to protect the wires.
If any wires proceed up to the ceiling for lighting, cooling etc., those will be protected by ceiling panels that can either have space to run future wires, or a chase installed, or the panel will be removable for repairs, or a combination of any of these.
RV/Vehicle wiring MUST be stranded, NOT solid wire!
15 amp outlets and lighting will be served with 12 gauge/with ground 'SO'-style cable, also known as Extension Cords!
Yep, per my Licensed Electrician friend who gave me the staright poop on this...I will also be tinning the ends of the wires with ROSIN-CORE solder so it makes for better connections.
DO NOT USE ACID-CORE SOLDER, IT WILL EVENTUALLY DISSOLVE THE WIRING.
20 amp outlets, lights and circuits will be served with 10 gauge SO cords.
Sure can't beat the prices, especially if I get them as seconds or on sale at the discount stores.
If larger cuircuits are needed, I will find out what are the appropriate gauges of wire to be used for those applications, and use the appropriate stranded wire.
A circuit panel will be connected to the 'shorepower' cable with a disconnect so that the panel either takes power from the shore supply, OR the genny, but NOT both at the same time...don't want any polarity or backfeeding problems that will turn my wiring to smoke!
If I use GFCI breakers right at the panel, they will protect any circuit directly down-line of that breaker...this will also make installations easier, as GFCI outlets are bulky and somtimes hard to fit all the wires in the box.
Which reminds me:
All electrical boxes, whether for switches, outlets, etc. are stamped with their volume in cubic inches. These are limits on how much stuff you can SAFELY load any box with connections and devices. PAY ATTENTION TO THESE SPECS!!!
The ground for the main panel will ALSO be grounded directly to the bus chassis and bodywork; I want to eliminate any possible chance of electrocution just by leaning on the bus.
The ground and neutral wires from the panel will be kept separate at all times.
I will also keep in the 'shore power cable storage box' a circuit tester to let me know that the shore power I plug into is grounded and connected correctly. These testers plug into a standard 15- or 20-amp outlet, and let you know by indicator lights what's up. IF plugging into a 30-amp outlet, use an adapter to check it, too.
All cables that exit the conduit and run free under panels, etc. will be supported no less than 18 inches apart, to prevent vibration fracturing of the wires. All wires that enter outlet and switch boxes will be supported within 6 inches of the box for strain relief, and to reduce wire flex and breakage.
If the wire is to be in an exposed but dry (interior) space, I will use armored cable with the appropriate gauge cable and fittings. Don't forget the bushings on the end of the cable armor to prevent chafing of the wires on the metal.
If the wires are to be in an exposed EXTERIOR space, I will use waterproof armored cable AND fittings.
If the wire passes through any openings, I wall make sure that there will be appropriate grommets or other measures to prevent chafing of the insulation.
I will be using commercial grade outlets and switches, as they are heavier duty and more reliable in the long run. I think this saves money and time, too.
I will think twice, no, THREE times before I use any USED electrical equipment, as I have no idea if the equipment had been previously installed correctly or subjected to unusual loads that may have done unseen damage.
Circuits that will be protected by the GFCI breakers will include, but are not limited to, the kitchen area, the bath area, and any exterior outlets.
These will be 20-amp breakers.
I will NOT use any "push-connect" wiring on the back of outlets and switches, as they have a tendency to arc if loose or vibrated. I will ONLY use the correct screw connections, and will ground all circuits.
I will leave a minimum of 6 inches of wire in each box, as I will need adequate lengths to ensure I have the connections properly made.
I will also check each circuit I have finished, using an appropriate meter.
That's it for now, more to come (eventually)
GoneCamping 01-06-2007 09:23 PM
Please clarify the above statement?
If you are referring to Coach 12v wiring that is correct. If you are referring to 120vac wiring that is in error. One quick look at my Travel Trailer and another at a friends Fleetwood Motor Home tells a different story, they have standard 12/2 solid house wiring... My trailer is a 2004 model and his motor home is a 2002 model both with RVIA certificates...
On edit: I also spent a couple of Saturdays this summer tearing apart a Prowler fifth wheel that had the roof cave in, this is where I got many of my RV specific hardware items. I happened to save some of the wiring from that rig too, including the switch system between the Microwave and water heater (shared resource). That unit also had standard 12/2 wiring...
GoneCamping 01-06-2007 09:47 PM
To back-up my statement, I dug out the camera and snapped this...this is under the end table beside the sofa in my trailer....
http://www.gonecamping.net/images/bus/inside/outlet.jpg
Les Lampman 01-06-2007 09:57 PM
Hiya Cliff,
Well, there's always a a point of contention with this subject. I think a lot of folks are of the opinion that in something that moves that stranded wire is the way to go but I'll be the first to say that's not universally agreed upon. Since my background is so heavily marine and solid wire is NEVER used in any circuit I'm in the "stranded wire is best" camp but I've also got a classic Class C Beaver motorhome that has house-style (solid) wire in it; it's now almost 30 years old and seems to be doing fine so I can't say categorically that solid wire is horrible.
The issue centers around the solid wire work-hardening and perhaps breaking where it enters connections (like in an outlet box, breaker panel, etc) due to vibration on the road and constant movement.
Technically I think there's a better arguement for using stranded wire than not and I'll use it myself but I don't think that means that everyone has to given that solid wire is used in production RVs. To a large degree I think a lot of converters believe that stranded wire is better and feel that production builders are more interested in keeping costs down and profits up and therefore that's why they use the cheaper solid wire (custom coach companies all use stranded wire to the best of my knowledge).
I think you have to look at the use you're going to give your conversion and make a decision that's best for your needs.
GoneCamping 01-06-2007 10:13 PM
You gotta keep in mind that the point where the wire is connected is also vibrating right along with the wire, so all things being equal if everything is vibrating at the same rate it's more a question of things vibrating loose rather than breaking. Be that as it may, I had to take issue with the tutorial since it runs counter to what's actually out there. In real life, these RV's are made by the thousands year and and year out and they almost all universally use solid wire. So to say that it MUST be stranded is not doing your readers a real service.
I'm just trying to be objective with information that I know to be consistant with the facts. Not trying to flame anything or anyone....
Les Lampman 01-06-2007 10:27 PM
Re: General AC Wiring (or, how I would do it)
Just to clarify, since I'm not sure I'm interpreting what I read above correctly, here is some information on grounding.
NEUTRAL-TO-GROUND BOND SWITCHING (RV AND MARINE APPLICATIONS)
As required by NEC code and UL specification 458, inverter/charger installations in the U.S. that are used in RV or Marine applications employ ground-to-neutral switching. The purpose for this requirement is to ensure that all the neutral conductors are connected (“bonded”) to a single ground point in a three-wire (hot, neutral and ground) AC system. This prevents a voltage difference from developing between the vehicle/boat’s AC neutral and the external AC source’s (generator or shore power)neutral, which may cause an electric shock or cause nuisance tripping of GFI’s.
When the unit is operating as an inverter, the AC output neutral should be connected or “bonded” to the frame/hull (chassis ground).
When an external AC source (AC shore cord) is provided, the inverter’s AC output neutral should be disconnected from the frame/hull (chassis ground) and allow the “bond” to be provided by the external AC source.
The requirement to switch the neutral can be met by your inverter internally or can be easily met by using an external relay to connect and disconnect the external AC source’s neutral.
If another AC source (on-board generator) is included in the RV or boat, this AC source neutral is required to be connected to ground when it is being used, and to disconnect all other neutrals from ground. An AC transfer switch can be used if it switches both the shore cords and generators neutral.
In other words, if you're connected to shore power your AC system neutral must be grounded through the shore power system and not to your bus frame.
Les Lampman 01-06-2007 11:44 PM
I think the point is that things are not moving together; the circuit breaker box, or the outlet box, or the switch are all solidly fastened to walls and such. The agument is that the solid wiring if not completely and securely fastened will move around as the wires bounce and jostle going down the road which puts stress on the connections; this is well proven and universally accepted in the marine industry since that's such a rugged environment I believe that the feeling is if it works there it ought to be even better in an RV.
Your observation that it's accepted production RV practice to use solid wire is true but I also believe that a lot of folks doing their own conversions are doing so in order to end up with something much better than they perceive a production RV to be and that typically means massive upgrades to what are thought to be shoddy practices in the production RV world. This isn't about "facts"; it's about very subjective and personal feelings.
There have been a few books written about coach conversions. I've read several by Dave Galey and George Myers, both of whom are well respected in the conversion community. They don't agree on the wire to use for the AC system; Mr. Galey says "Although I have seen Romex used in bus conversions, I do not recommend it since sold copper tends to work-harden and become very brittle under vibrating loads, hence the risk of breaking". Mr. Myers says "The most serious failure mode of any wire happens when the wire moves relative to something next to it and the insulation wears through. More flexible wiring has a higher probability of moving..." so he doesn't recommend "Boat Cable". He does recommend running your AC wire in steel conduit, second would be plastic conduit, the next choice BX. And...be sure that the Romex you get is Type-NM. [I don't agree with Mr. Myers (although I do on many other subjects); if what he says is true we'd use Romex on boats and that never happens...that's just my prejudice.]
I highly doubt we're going to end the controversy here! Until some definitive tests are done and the results made public (not likely to happen) there will be the Romex camp and the Boat Cable camp ever arguing over which is best! :lol:
There isn't a tutorial here per se; up to this point there was one persons post about how he was going to approach the wiring in his conversion. I doubt he intended a disservice to anyone.
the_experience03 01-07-2007 12:20 AM
12/3 Extension cords which equate out to a 12/2 NM (I don't understand the difference in numbering conventions) were a whole lot cheaper than solid wire when I did my conversion. On top of that, every circuit could then easily be color coded.
paul iossi 01-07-2007 01:23 AM
wiring
Just to help confuse the issue, there are different types of stranded wire, industrial AC stranded wire for installing in conduit has much larger strands than automotive or marine stranded wire, and then their is flexable, fine stranded wire used for extension cords and welding cable.
In my opinion the most important thing when wiring is to make sure that you keep everything properly supported and secured in a neat package that can be easily serviced when necessary. Just for the record I'm a stranded wire and busbar kind of technician because if the smoke gets out you need help. :twisted: :shock:
