-   -   Paint prep (http://www.skoolie.net/forums/f13/paint-prep-5694.html)
opus 07-20-2010 09:20 PM
Paint prep
How about a light sandblasting instead of sanding? Sure would be easier and quicker.
Anyone ever try it?
bodaver32 07-20-2010 10:27 PM
Re: Paint prep
Opus,
Give a little more information about the current condition of your rig. Is it painted, rusty, bare metal and you want to repaint it? Sandblasting will take it down to bare metal, and be very careful in sandblasting large flat areas - it will warp it. If you are thinking you can lightly blast it, just enough to rough up the paint - the texture of the blasted paint will show through the new paint like you wouldn't believe.
Sandblasting is a messy time-consuming job, I farm it out as often as I can.
opus 07-20-2010 10:38 PM
Re: Paint prep
Its nicely painted school bus yellow. I am going to repaint it. I thought using a very fine sand would be a better option than sanding....ugh. I was just wanting to scuff it up, as I would in sanding. I will probably end up rolling the paint on. Seems to be the way everyone else does it.
bodaver32 07-20-2010 11:07 PM
Re: Paint prep
I would get either an electric or air DA sander and go over the entire bus. You would be amazed how fast it will go. Much faster than blasting or anything else. An air DA requires a large air compressor to operate - so electric may be your best bet. You are not sanding to get down to the metal, just to get the shine off the old paint and give the new paint something to stick to.
I sprayed mine, but I was after a different look.....
http://willysmjeeps.com/v2/modules/g...ize_9_6_09.jpg
opus 07-20-2010 11:29 PM
Re: Paint prep
I too was thinking a DA, I have enough air. I was wondering about rub rails and all those odd things, hence the sand blasting thought.
Nice looking ride, '57?
bodaver32 07-21-2010 09:04 AM
Re: Paint prep
It is a 1955 Ford.
The interior work is ongoing and slow. I have a posting of it in the conversions section, but I haven't updated it in a while. I need to do that and get everyone caught up.
opus 07-21-2010 10:58 AM
Re: Paint prep
What grit would you suggest?
i have painted 5 buses, and i prefer to use an electric palm sander. Should only take an hour or so to do the entire bus. Like someone else stated. You do not need to get down to bare metal, all you want to do is make the old paint dull (not shiny) Then i wipe the entire surface down using paper towels and mineral spirits. none of that save the earth imitation paint thinner crap, but actual mineral spirits. Then wipe it down again. This removes all of the paint dust you just created with the sander. I also like to wear latex surgical gloves when i am dealing with paint. Makes cleaning my hands a lot easier!
I don't remember what grit i use....somewhere around 180 or 220 i suppose.
bodaver32 07-21-2010 04:33 PM
Re: Paint prep
I normally start with 220 to cut through the old paint then do a bit finer to get rid of some scratches.
Scratchy 07-21-2010 04:36 PM
Re: Paint prep
I used Scotch brite pads and elbow greese on the ribs and areas where I couldn't get my DA into. Again just trying to remove the shine for the new paint to stick.
Good Luck.
opus 07-21-2010 04:45 PM
Re: Paint prep
Very helpful, thanks.
