-   -   a few plumbing questions (http://www.skoolie.net/forums/f13/a-few-plumbing-questions-6204.html)
lornaschinske 12-25-2010 10:33 AM
Re: a few plumbing questions
I prefer the basic shurflo multi fixture 2088. Stay away from the Whisper king and other "fancy" ones. They crap out pretty fast. if you need info on your plumbing systems...
http://www.marxrv.com/tech.htm these are from a stick-n-staples RV outlook but apply quite well to a bus conversion. Mark is big on "upgrading" his RV systems.
http://www.phrannie.org/phredex.html A Note about Phred's Poop Sheets. Save them to a something (whatever you save to) and hang on to them. I'm not sure if phred is still around. They haven't been updated for several years but still apply.
lornaschinske 12-27-2010 02:06 PM
Shurflo 2088-422-xxx Classic (or the 2088-453 Premium Plus if you need more GPM). In the Class C is a 2088-403-444 Classic Series (manufactured 10/95... 403's are no longer made I think... this is our newest pump we are running. We have Shurflo 2088-422 pumps on the food cart that are much, much older) 2.8 GPM at 45 PSI... 10.6a@12vDC... I can run the sink in the kitchen (home style faucet) while someone takes a shower (low flow 2.5 GPM max shower head). No problem. The Classic is the most dependable of all the Shurflo pumps. They last for years without a hiccup. You can get them for under $75 most anywhere. A 2088 Classic will go in the bus (I will have an automatic dishwasher which needs 45PSI... we will only run off our fresh storage tanks due to the high filtration we put the incoming water thru). No matter what pump you get, either run a sediment filter on all your water BEFORE it enters a storage tank or the pump (even city water gets sand/dirt in it) or get an "inline strainer" for your pump. We run a sediment filter (the kind with a permanent screen used in well pumps) plus a 0.5 micron filter (filters out almost everything and knocks the water pressure down to a dribble). These pumps are made to run dry but do not like dirt or sand in them. The fancier pumps seem to burn up after a couple of years. That includes the "Whisper King" which is supposed to be so quiet. Attach your pump to a secure spot (like a floor) with a sound/vibration mat under it. Something like a rubber mat or a piece of that dense foam that goes under sleeping bags (yes, I know they come with little rubber feet... that may be enough but sometimes it's not). I have heard a lot of folks complain about the noise the pumps make but I suspect it has a lot to do with how the pump is mounted and the sound transference properties of what it is mounted on in the first place.
You will need to know what the GPM of your shower heads and kitchen sink faucets are. Too low a pressure in the Kitchen sink and the sprayer won't spray if you are using one of those pull-out main spray head faucets like this...
http://images.lowes.com/product/conv...34823944lg.jpg my problem... but I hate my faucet and will go with an old-fashioned cheaper little side sprayer for the sink like this... http://images.lowes.com/product/conv...99906904lg.jpg We are installing a water softener in the bus because the hard water is playing havoc with the shower and faucet sprayers... cheaper to replace that side sprayer than the one in the faucet.
BTW, I have heard nothing but bad about the Extreme Smart Sensor Series. If you go with them, research the recent stuff to see if they have fixed them (the micro processor or circuit boards were burning up). Awfully pricey for something that craps out in less than a year.
lornaschinske 12-27-2010 04:28 PM
Originally Posted by Iceni John
... plus whatever filters to make my water taste like water. (Note to self - don't fill my tanks from Mono Lake in California. All that disolved arsenic is not conducive to a long and happy life.)
If you want to avoid arsenic you need a Reverse Osmosis system. How do I know??? I am sitting in a town that has very high but "acceptable" levels of arsenic in the water. We don't have an RO system but we drink very little water here. We use RO ice for our food cart. When we first moved out here (last summer) all the "locals" told us to not drink the water! By that I mean every person we spoke to said don't drink the water within minutes of meeting us. They all drink/cook with bottled water. That is just creepy.
Good luck with the pumps!
