One Piece Skoolie Door
We wanted to keep our original door for various reason. Money and having to special order a door was part of that. So this is what we did. Lowes has a retractable screen door (looks like a sideways roller shade) that looks like it may work for a screen door. We'll see. But for now...
Building an Original Bluebird Two Piece Door into a One Piece Door Because our original door was in such good shape and needed no repairs made to it due to rust. We decided to reuse the door. The two piece door took up a lot of room and we couldn't come up with a good way to lock it. I had gotten a couple lengths of (never used) steel landscape edging off Freecycle.org. It was very simple to do. David removed the door by unscrewing a pile of little screws that held the door onto the piano hinge. Then he trimmed down the piano hinge using a cut off wheel and my small hand held trim router. We also stripped all the hardware and trim off the door. We had several sets of old door hinges so we used them to hinge the door. We laid the door, face side down, on a flat surface and used a straight edge and shims to make sure the door was completely flat. We cut a strip of polyiso foam board insulation to fit tightly inside the groove between the two door panels.We measured and trimmed the length of the landscape edging to fit the door. Then we clamped the trimmed edging to the door so that it wouldn't move. We drilled small pilot holes thru the edging and the door. We reused the tiny screws that were used to attach the piano hinge to the door. Then we rehung the door. A chain connected to threaded eye bolts will prevent the wind from catching the door and tearing up the hinges. As you can see the landscape edging just fit between the two panels of glass. http://www.skoolie.net/attachments/p...baa9ec7e89.jpg We cut the original hinge off the door. Then rehung the door with 6 door hinges bolted to the door with screws and nuts. The other side of the hinge wast attached to the frame with screws from the siding. http://www.skoolie.net/attachments/p...f50b899ad4.jpg Turning the original in-swing bifold door into a one piece out swing door. http://www.skoolie.net/attachments/p...c0454f5efb.jpg The chain helps keep the door from swing out too far and damaging the hinges. The center strip is a section of metal landscape edge attached with screws. The small gap was filled with a piece of foam board insulation, cut to fit. http://www.skoolie.net/attachments/p...f4979b29d2.jpg Close up of the metal landscape edging strip. http://www.skoolie.net/attachments/p...bf34744f41.jpg Another close up. The metal edging fit just between the two glass panels on the door. This was cut-& pasted with a little addional info added from our webpage. It can be found at http://aluminumasylum.webs.com/bluebirdfe.htm These photos can be found at http://s570.photobucket.com/albums/s...%20Conversion/ A copy of the article "One Piece Eagle Door" can be found online at http://aluminumasylum.webs.com/onepieceeagledoor.htm It used to be all over the internet but now it's gone. No pics because I didn't know how to save at that time. (NOTE: This info is now in Dave Galey's second edition printing of his "The Bus Converter's Bible". I definately recommend that you purchase this book. It is invaluable if you are converting or thinking of converting any kind of bus. 2/2006) |
Re: One Piece Skoolie Door
I debated about doing that to but some of my glass was broke and cracked as is. Also determined there was too much glass and it was too heavy. mine was also full glass doors.
How are you locking the door now when you're inside, and when you leave?? This is what I plan in doing with mine too, but I was planning on reusing the piano hinge after I take it off and flip it around so the door opens out... I just can't figure out how to lock the door from the inside, I don't want to use a master lock because I'm afraid someone could lock me up inside, lol... so i thought might have to install a door knob too if I did this.
We could not flip our hinge on the BlueBird. The body side of the hinge was part of the post and could not be removed without taking apart half of the front section. |
Did you ever come up with a solution for a door latch/handle type situation here?
Blank slab exterior residential doors can be had brand new at Home Depot for around $110. Recycling places will have them for half of that or less. Nat |
For me it is about time constraints and the ability to see clearly through the door. The insulation factor is a non issue for me as I'm building an insulated wall/door behind the drivers seat to isolate the cab from the living quarters for wintertime living. It is essential up north where condensation and ice are a problem in the winter months. Saves a lot of wiring/electrical nightmares.
I just got a bbird tc2000 which has the folding door, I plan to keep the door for the visability it gives, and to rework it the way my farther did on a bus he converted years ago. He simply installed 3ea. 1X1/4" steel bars at top, bottom, and center across inside of door to make it rigid, then removed the rubber seal from the edge of the door, then replaced the seal with a 1X4 or 5" sheetmetal channel with a wood core which he placed inside the channel. Then just install a regular door knob set that can be locked. Took the top, bottem guides, upper weather strip, and the drivers coltrol lever off the door, and the door will open outward to about 90 degrees. So it can be set up the way I thought without reversing the original hinges.
I found it way easier to install a nice larson storm door with built in dead bolt lock. I didn't like the view being obstructed by it not being solid window.
