-   -   Getting roof A/C unit on top of the bus (http://www.skoolie.net/forums/f13/getting-roof-a-c-unit-on-top-of-the-bus-6689.html)
bapos 06-08-2011 06:51 PM
Re: Getting roof A/C unit on top of the bus
I would park a truck beside it and use it as a scaffold.
That and I would call people close to you that might be able to help?
Let me know
Bapos
Redbear 06-08-2011 10:00 PM
A friend with a forklift?
Diesel Dan 06-09-2011 10:43 AM
I have a much bigger hood on my school bus than you do on your shuttle, but I was able to enlist the help of one friend and we lifted the AC onto the hood, then we both climbed up on the hood and lifted it from there onto the roof. You just need to find some intermediary platform to set it on, like another vehicle or something. You might need two A-frame ladders to get the job done. The AC is manageable for 2 men of average strength, so long as you have good positioning.
penguin 06-09-2011 11:25 PM
If you have a equipment rental business near you, there is a tool called a genie lift which you can rent for about $50-$75 day. It is used to lift duct work, a/c units in buildings, but you might be able to lift your a/c on top of the bus. They are a manual roll around lift which will lift from the ground to about 16'. They have two sizes one can life about 500 lbs, larger one can lift about 750 pounds. I used one to lift my car lift from the ground to vertical without breaking a sweat.
Penguin
putterspitt 06-10-2011 03:14 PM
2 8' step ladders and a 2x12, set it up on the board, then 2 of you get up there and lift it up to the top. really easy, although I did climb ladders for a living for 28 years........
browncrown 06-12-2011 04:52 PM
I did it the way bapos said. Parked my truck next to the bus and with a friends help, slid it up on the roof...not the most professional way of doing it but it worked. Would not reccomend doing it this way though if you have nice paint up there. I put mine up before paint so it didn't matter about scratches.
bapos 06-12-2011 10:36 PM
Good Job.
This is what this site is about helping each other if it be physically or educationally?
Thanks to everyone here sharing.
