-   -   Dual Wheel Valve Stem Extensions (http://www.skoolie.net/forums/f13/dual-wheel-valve-stem-extensions-6967.html)
Stuff 09-09-2011 04:00 PM
I am looking at putting some valve stem extensions on due the fact i have the hard metal stems that are practically not reachable!! I do not like traveling far without knowing the true conditions of my tires even though i hiked it a 1000 miles home without knowing previously.
I was thinking of ordering these... http://www.autoamenity.com/Wheel-Simula ... tender.htm
http://www.autoamenity.com/images/AirMaxInstalled.jpg http://www.autoamenity.com/images/Ai...alledinset.jpghttp://www.autoamenity.com/images/AirMaxdiag.jpg
I think these would be a godsend and make it a heck of allot easier to check!
What is the opinion of the forum?
somewhereinusa 09-09-2011 04:42 PM
Re: Dual Wheel Valve Stem Extensions
Those are fine, for just a little more money you can have these
http://www.iowa80.com/DirectionsWEB/...ization+System
They come in different pressure ratings.
For a lot less money you can get these
http://www.iowa80.com/DirectionsWEB/...alve+Extensionor
http://www.iowa80.com/DirectionsWEB/...ion+5-1%2F8%22or
Stuff 09-09-2011 05:28 PM
i like that first one you linked. I need the lines to come out to the front so that would be the best. I assume there is a hook up there for adding air equally to the tires?
also 100 psi is a bit much for my rig
