-   -   Joel and Brittney (http://www.skoolie.net/forums/f11/joel-and-brittney-7444.html)
j12784 04-05-2012 03:51 PM
Joel and Brittney
We have a cat 3802 engine thomas built 36 pusher
http://www.skoolie.net/attachments/p...eb78148c6a.jpg
http://www.skoolie.net/attachments/p...9865de7a12.jpg
http://www.skoolie.net/attachments/p...73f19090f7.jpg
j12784 04-05-2012 03:58 PM
Re: Joel and Brittney
Got all the seats out. Got the materials to move the heater from the back to the front where it would benefit us most while travelling down the road.
Anyone have any suggestions on what to fill the holes with in the floor?
I plan on using some foam insulation with some plywood on top of it for flooring.
RevBill 04-05-2012 05:58 PM
Congrats and Neat Bus .. enjoy .. that's just about exactly the size/design I am looking for .. looking forward to watching your build-up and conversion ..
syke 04-05-2012 06:21 PM
Wow! Great platform. :) Looking forward to more pictures.
Did I see a little grease in the background of one of those pictures? 8)
lornaschinske 04-05-2012 06:24 PM
Originally Posted by j12784
... Anyone have any suggestions on what to fill the holes with in the floor?...
http://www.skoolie.net/attachments/p...6e6d50f853.jpg
How I patched the holes in the floor that were left behind by the various bolts and screws. First I used a small hole saw and cut thru the rubber flooring. The pilot bit made the screw holes nice and clean. A dot of clear elastometric roof seal (Henry's brand from Home Depot) was plopped over the hole. A thin piece of metal flashing was cut with a pair of kitchen shears and pressed into the wet elastometric caulk. The clear seems to be less messy than the black. I used both kinds because I had a partial tube of the black. And it was the last tube of the black I bought.
bus-bro 04-05-2012 08:49 PM
A blob of caulking?
Tango 04-06-2012 12:05 AM
Weld'em.
j12784 04-06-2012 12:10 AM
I think a few blobs of caulk will do nicely since i'm covering the floor with some water resistant foam.
j12784 04-06-2012 12:11 AM
Originally Posted by Tango
Weld'em.
oh. how exactly would I go about welding them?
bus-bro 04-06-2012 12:27 AM
Weld'em.
If you got to ask, you don't want to do it. First, you have to buy a wire feed welder, then learn to use it on sheet metal. I could forsee the holes getting larger, not smaller.
