-   Mechanical and Drivetrains (http://www.skoolie.net/forums/f33/)
-   -   driving in mountains with FE 5.9 cummins and 545 Alison auto (http://www.skoolie.net/forums/f33/driving-in-mountains-with-fe-5-9-cummins-and-545-alison-auto-8063.html)
bansil 10-28-2012 05:24 PM
My views and thoughts on driving in the mountains with a FE bus with the 5.9 Allison 545 combo.
I just returned from a 400 mile trip from Mnt City TN south thru Boone via 421 past Winston-Salem, I learned a lot and would like to pass it on for others,since I couldn't find the answers I needed.
Disclaimer:these are my two penny"s and use them as you like.
I was having over heating issues (due to tranny temps climbing as well as coolant temps climbing) not dangerously high but high enough I had to stop and sometimes not continue up mountain's since I have had the bus for the last 6months.
the answers to POINT ONE (1 penny).............................
GOING UPHILL
I asked a few older school bus drivers"how do you drive up this mt, w/o over heating or killing the trans?"
they said (I shorten the stories but this is basic info)"2200 rpm is the magic number,find your speed in each gear at 2200 on flat ground and make that the minimum plus 5 mph for each gear"
I approached the mountain and slowed to about 25mph, shifted down to 2nd and rolled into throttle building boost and held it at 2200/2300 rpm when I hit the rpm i was doing 30 mph and several miles later I was in Boone,N.C. coolant/trans never went above 185 engine and 200 trans (convertor out)
Perfect!!
We continued on following same guidelines I established:
1st gear=15-20mph 2200 rpm
2nd gear=30-35mph 2200 rpm
3rd gear=45-50mph 2200 rpm
4th gear was useless to me since the rolling hills never let me use it with out being below my target rpm, and tranny would slip as boost built and temps would rise,so I drove a gear down,and 50mph.
POINT NUMBER TWO (2nd penny)
GOING DOWNHILL
Heading out of Boone down 421 was the mountain; an evil 6 miles down into N.Wilkesborro
I put tranny into 1st at top of hill and crested at about 10 mph (no lockup convertor)rpm's made tranny shift into 2nd,since I was playing the game of precaution I was nervous and used 30mph as my "set speed" I had to apply the brakes several times and even pulled over and checked brake temps at
a spot between the runaway ramps...cool to touch OK I'm good so we continued on.so I basically coasted hoping the tranny and engine would hold us back
Here is the point :wink:
on way back,I climbed the mt with no worries and no temp variation...cool...but I had 2 down hills that worried me.
I crested and rolled by the Eastern Continental Divide sign and knew there was a red light at the bottom of the grade...
I shifted into 1st gear and drove at about 1500 rpm to make the transition from flat to down hill, as I was "driving" down the mountain contemplating how I would approach this light I realized that I was all ready 1/3 way down and still doing 15 mph!!!! :shock:
As long as I "drove" not coasted, the tranny held back just fine....so I drove down that incline in 1st gear at 1500/1700 rpm...I feathered throttle to maintain pressure but not rev motor.
I was happy.
The road out of Boone back towards Mt City is a lot steeper with a damn gas station at the bottom.
I "drove" down at 20 mph and 2000rpm,when engine started to creep up I used my left foot to apply the brakes for a split second(2 times total) so I still had throttle pressure applied
Sorry this is so long winded, I hope this helps someone out and gives them an idea or 2...
SIDE NOTE: I AVERAGED 8-1/2->9-1/2 MPG AT THOSE RPM'S
crazycal 10-29-2012 10:40 PM
Re: driving in mountains with FE 5.9 cummins and 545 Alison
I kinda figured that was why my trans temp got so high coming back from Tenn. I was babying it going up the hills. I still think my trans slips more than it should.
PossumLiving 10-30-2012 01:07 AM
That is good info, indeed. Do you know what your rearend ratio is? I have the same powertrain in my TC2000, and my rearend is 4.78:1.
bansil 10-30-2012 08:09 AM
after the snow melts I will crawl under and look...
travelinwithus 10-30-2012 09:24 AM
Thanks for posting. We are headed to the east coast into the mountains so I will be sure to keep your info in mind. I have a manual tranny so should be a little easier for me, I hope...
bansil 10-30-2012 10:24 AM
This is for the 5.9, I have no idea what kinda RPM's the 408 likes or what max rpm's are
travelinwithus 10-30-2012 10:19 PM
It pretty much maxes out at 3000 RPM, Turbo starts spooling at about 2000 RPM. Not sure that spooling is the appropriate terminology there but 2000 RPMs seems to be when it starts the power band (to use 2cycle dirt bike terminology). Once we get into the mountains I will do some experimenting and let you know how it goes. We have a week or two before we will be in the mountains though.
kimberlink 11-14-2012 06:55 PM
Thanks for the info... Me being simple minded I thought put it in drive (4th) an go. unless I wanted to go faster up hill then pull down into the lower gears. And heading down th hill pull it down and let the engine help brake. :oops: Ya just save my butt again thanks ya'll...
bansil 11-14-2012 08:30 PM
It's just a big learning game for all of us :lol: I'm glad it help'd
Jarlaxle 12-25-2012 07:28 PM
What RPM's are you spinning at 60MPH?
