-   -   Trans Air units (http://www.skoolie.net/forums/f13/trans-air-units-8593.html)
Malkieri 06-28-2013 06:44 PM
Trans Air units
I have a couple trans air after market units installed in my bus and was thinking that as they run off DC I could probably hook them up to an inverter or battery bank and run them as house AC.... Looking for opinions both for and against this idea.
http://www.skoolie.net/attachments/p...g?t=1372451194 Rear air handler, front is the same but a bit smaller.
The condensers are skirt mounted under the bus between driver seat and rear wheels. There is nothing connecting these to the engine other than a couple wires to each.
I looked them up and I think they are 31 amps @13.5vdc for the condensers and the upper units should be around 10 amps @13.5vdc. I have not spent a ton of time on AC as I always thought I would just get a window unit... but these are there and work REALLY well...what do you all think? Is this even possible?
family wagon 06-28-2013 08:59 PM
Re: Trans Air units
That's not much power.. surely there must be a compressor driven by the engine?
wmkbailey 06-28-2013 09:17 PM
Re: Trans Air units
Most of the Trans air have motor driven compressors. I was looking into them, but hard to use when the engine is not running.
penguin 06-28-2013 09:50 PM
Re: Trans Air units
I have that unit in the back of my bus and it does have an engine driven compressor. I had had thought about powering with AC/DC it until I found that out as well
