-   -   Senza Legno, Senza Pontilli (http://www.skoolie.net/forums/f11/senza-legno-senza-pontilli-8798.html)
Stu & Filo. T 08-17-2017 03:04 PM
1 Attachment(s)
Well, after a 4 week delay waiting for FedEx to pickup the damaged unit & waiting for the replacement I finally was able to bolt down the second unit. I'm still waiting for the 10gage Marine grade wire I ordered to wire it all in.
Word of advice to all those who have installed these roof top AC, Go back & retorqe your mount bolts, It calls for 50 in pounds, I took them to 50 yesterday & went back this morning after the seal settled & was quite a bit loose. We do the same thing for ACFT windshields.
Now to go back & remove the first one I installed to correct my mistakes.
Stu & Filo. T 08-17-2017 03:06 PM
1 Attachment(s)
Don't know why the site gives us the option of uploading 8 pics but only does 1.
Stu & Filo. T 09-27-2017 06:00 PM
1 Attachment(s)
Well finally have a little more progress to report, Finally have 2ea 15000 BTU Ac units installed & 2ea 10speed maxxFan's with thermo controlled remotes. These can be programmed to open at a set temp to circulate air thru are also reversible & can be used as ceiling fans when closed
Stu & Filo. T 09-27-2017 06:03 PM
1 Attachment(s)
Now Have to work on building the duct work for the AC units
