-   Plumbing, Water and Waste (http://www.skoolie.net/forums/f50/)
-   -   Black & Gray Tanks (http://www.skoolie.net/forums/f50/black-and-gray-tanks-8942.html)
Stu & Filo. T 01-02-2014 09:57 PM
Black & Gray Tanks
What would advantages & disadvantages be to having one 90 to 100 gal waste tank?
gbstewart 01-02-2014 10:08 PM
Re: Black & Gray Tanks
Are you talking just one tank for back and grey water?
People do it , you will have more grey water and if your not carefull and the tank fills up and over flows in side it can be yucky if you have the black tank spilling out as well :( with 2 tanks if you had too you can empty the grey water into a pail and dump it.
it would be less work to install just on tank, I think its up to how you would want it, for me I like 2 tanks
Stu & Filo. T 01-02-2014 10:38 PM
Yes I'm thinking of just one tank around 100 gal, I'm putting in a 100 gal freshwater tank, I already have a mercerating toilet for pumping into the tank & I'm planning on using another pump on the waste tank discharge because the perfect place for the tank is on the right side of the bus but I have a storage bay on the left where I'm wanting to put my discharge controls
Redbear 01-03-2014 07:50 PM
Re: Black & Gray (& "Brown") Tanks
Originally Posted by allwthrrider
. . . I already have a mercerating toilet for pumping into the tank . . .
I think we need to come up with a fourth tank description - a "brown" tank! A "brown" tank would hold macerated waste products with no solids. If the macerator was not built into the toilet, one could put a small black tank right under the "drop" where it needs to be so that gravity does its job, and then chop/pump the contents into a large "brown" tank that could be located anywhere that is convenient!
ol trunt 01-03-2014 09:46 PM
I long for the olden days when the only sound you heard upon flushing the toilet on board a train was the "klickty Klack" from the railroad track. KISS---well, not any more I guess :lol: :lol: :?
turf 01-04-2014 06:19 PM
the only draw back to a big tank is it needs room. most of the underbelly of my bus was taken up by other items... ie generator, batteries, spare tire carrier, stairwells and fuel tanks. i could only fit a small 40 gallon tank. i have 2 more fresh water tanks to work into my system, but dropped them out of the build for the space they consume.
it depends on your platform.... if you got the space.. bigger is better
Stu & Filo. T 06-18-2014 12:15 PM
1 Attachment(s)
Decided to go with one of these fuel tanks off another Crown that was crushed, capacity is 112 gallons, mounted upside down with a macerating pump off the filler neck :D , question is can I use the sending unit as level sender to a fuel gage or will the waste just corrode it real quick ? :D :) :o
sunfighter 06-22-2014 12:16 PM
1 Attachment(s)
Have you considered a home made macerator? a common garbage disposal unit. :)
lornaschinske 06-22-2014 04:21 PM
Alternative is to buy one...
Three low cost macerators courtesy of Amazon.com
12V Macerator Water Waste Pump 45 LPM 12GPM Toilet RV Trailer Camper Marine Boat by AC AUTO $59.99 & FREE Shipping
http://ecx.images-amazon.com/images/...L._SL1500_.jpg
Aidi 12v Macerator Waste Water Transfer Pump 45 lpm / 12 gpm RV Boat Marine DC $90.05 + $5.49 shipping
http://ecx.images-amazon.com/images/I/41GOxRwn1sL.jpg
Johnson 12V Macerator Pump by Johnson Pumps $105.55 + $8.99 shipping
http://ecx.images-amazon.com/images/I/41P6Z72fXkL.jpg
I have found that sometimes it is better to buy something new rather than build one from scrap/scratch. Of course that does NOT take into account if you need a customized item due to special circumstances. And sometimes you really just need to look up prices for what you are considering making just to see what the prices really are. It is surprising just how cheap you can buy a macerator for. On the other hand, it's amazing how expensive it would be if we were to buy power jacks for the bus rather than make our own (like over $1K per jack! :shock: :( I'm just way to cheap for that!). Do your homework! I had thought of going the garbage disposal route until I plugged a search into amazon.com just to see what I could save. Once I factored in having to buy either a used, possibly non-working garbage disposal or the cheapest/smallest new one at the store I work at ($84.96 and then modifying it to work, buying a macerator made for the job looked more attractive. So use the internet and research prices.
sunfighter 06-22-2014 04:40 PM
lornaschinske, you are spot on with your comments. A home made macerator is only inexpensive if one has a used one from say a known kitchen remodel, so they know it's good, and they have the skills and tools needed to build their own. for anyone else, the one's you showed would be the way to go. I guess I should have been a little clearer about that.
On that thought, another option is to check with boat salvage yards.(if you have one nearby) a lot of boats were equipped with macerators and many times they can be had reasonable.
