-   -   RIVET vs SPOT/PLUG WELD vs "BOLTS" vs GLUE etc. (http://www.skoolie.net/forums/f9/rivet-vs-spot-plug-weld-vs-bolts-vs-glue-etc-9093.html)
ol trunt 03-02-2014 01:18 PM
With the heated and often unsupported opinions expressed on this forum as to how best to fasten metal, I did a little research and found the following article. It is an interesting and easy to follow discussion of various ways to fasten metal parts together and hopefully will be an aide in choosing an appropriate fastening procedure for our varied needs. I was particularly interested to see which methods the authors considered "lite duty".
http://www.engineersaustralia.org.au/si ... rt%202.pdf
nat_ster 03-02-2014 06:49 PM
Re: RIVET vs SPOT/PLUG WELD vs "BOLTS" vs GLUE etc.
Lots of good reading in that link.
Good descriptions. pics, ect.
Nat
crazycal 03-04-2014 12:42 PM
No way! You forgot DUCT TAPE!
