Old 10-31-2010, 07:18 PM   #1
Chassis: International Genesis
1992 Amtran Genesis DT466 water pump replacement
So, today I set out on the task of getting to the water pump on my bus. After extensive review, I decided that the only way to do the job was to go in from the front end, not the inside/top. I began the task and at present am stuck with a steel frame cross member in front of the radiator that appears to need to be removed to go forward. Does anyone have any experience or insight into the proper procedure for accessing and replacing the water pump on this engine. The massive amount of work to get to the front of the engine seems excessive. Am I missing something? Thanks in advance for any help!
bryandavis is offline   Reply With Quote
Old 06-17-2011, 06:23 PM   #2
Re: 1992 Amtran Genesis DT466 water pump replacement
As a follow up to this post, I did have to remove the entire front. I removed a cross member, pneumatic fan shudders, radiator and fan. After all that, the water pump was very straight forward. I had to buy a new impact wrench to get the cross member bolt loose. Sorry, I didn't take any pics. Overall, it was a relatively simple procedure.
1995 Genesis Amtran automatic transmission converstion tmckinney International | Navistar Drivetrain 11 05-25-2019 04:48 PM
1997 AmTran International DT466 crazycal Skoolie Conversion Projects 158 07-21-2017 08:36 PM
Genesis Amtran one in the same ? norreh1 International | Navistar Drivetrain 3 01-22-2014 11:43 PM
wtb Drivers front window for 1993 Amtran Genesis bhays Classifieds | Buy, Sell, Swap 3 11-26-2013 06:56 PM
1992 DT466 Service Manual Timelord International | Navistar Drivetrain 0 03-10-2011 05:05 AM
