Old 02-16-2015, 09:27 PM   #61
Looks better already!
Old 02-16-2015, 09:49 PM   #62
Chassis: I.H.
What is the tan runner that I see down the middle of the floor? Mine is black and cracked from age but my wife wants to keep it for the "bus affect". Yours looks great!
Originally Posted by dond View Post
On the oposite wall is the TV/DVD.
HolyBus is offline   Reply With Quote
Old 02-17-2015, 07:00 AM   #63
The EOM flooring.
dond is offline   Reply With Quote
Old 02-25-2015, 10:09 PM   #64
The PS will have a pro mural of an outdoor scene.
Old 02-25-2015, 10:12 PM   #65
The EOM flooring.
Oops, OEM flooring!
Old 02-26-2015, 07:04 AM   #66
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Thumbs up
That has to be the best use of color to make a skoolie not look like a school bus. I'm not generally a fan of leaving a school bus yellow and I'm not sure if it would meet the Indiana,or any other state that doesn't allow school bus "chrome" yellow reqirement, but yours looks really nice. Well done.
Old 02-26-2015, 11:41 AM   #67
I would be very careful about how you have the bus loaded.
Those little tires can't carry as much weight as any 22.5" tire. You need to make sure you are not going overweight.
A friend of mine had a Blue Bird All American FE. I mentioned to him the need to weigh his bus before you had everything in place. He didn't think he was going to have any problems but he got his bus weighed anyway.
He discovered that he wasn't anywhere close to being overweight for the GVWR of the bus but he was getting way to close to the front axle weight rating.
The engines of FE buses are considerably further forward than on a Type 'C' bus or truck. If you notice instead of the engine being over the front axle the engine is so far forward that the transmission is more than halfway forward of the front axle. This puts a lot of load forward of the front axle. If you have other heavy stuff between the axles you can overload the front axle.
Good luck and happy trails.
cowlitzcoach is offline   Reply With Quote
Old 02-26-2015, 01:45 PM   #68
Thanks Cowlitz.
These 1000s have ballast weights behind the rear axle.
I have added nothing to the front of any consequence. In the rear I have added 4 group 31s (300 lb.) and 40 gal. water (300+)and an Onan 4KW (217)w/10 gal. gas (60 lb.). I have removed the 300 (or so) lb. WC lift. To avoid LIGHTENING the front axle too much I have also removed 1 ballast from the rear. The front is higher than when I 1st got it, enough to see it without measuring.
I selected this design because of the 19.5 tires.
"Those little tires can't carry as much weight as any 22.5" tire. " True but...
Our bus has 265/75/19.5 tires and they are rated at about 3415 lb. single.
A typical MH sized 225/70/22.5 is rated at about 3640 single.
As a "usetabe" bus driver This BB handles beautifully.
I plan to weigh her when I get to a scale, there's nothing near us out here in the AZ boondocks!
Old 02-26-2015, 06:28 PM   #69
Coachwork: ward
Chassis: international
Engine: dt360a
purty bus, and great info on tire rating!!!!!!!!!
claydbal is offline   Reply With Quote
Old 02-27-2015, 07:15 PM   #70
Thanks everyone for the kind words. Today I installed a wireless rear view camera..... awesome! Wired it on a switch and run it when needed not just while backing.
Wireless 5" Car Rear View Monitor Backup Camera Antenna for Truck Trailer | eBay
Old 02-27-2015, 10:25 PM   #71
Chassis: I.H.
Great build! More detail on the water heater that you went with. I may have found teh one I will use but not sure. I found a 4 gallon 110v unit at Home Depot by Ariston. It is the GL4S model. I haven't check the reviews yet but the size and price seemed right.
Old 02-28-2015, 08:09 AM   #72
HB, thank you.
I tried 2 of the HD ones you are considering, in the 6 gal size but they BOTH leaked after install. 1 leaked within the insulating jacked and 1 leaked at the fittings. HD did refund w/o question.
I went to LOWES and got a 6 gal. conventional 120v unit and am very pleased.
Shop Whirlpool 6-Gallon Electric Point-Of-Use Water Heater at Lowes.com=
Old 02-28-2015, 08:09 PM   #73
Chassis: I.H.
Thanks for the input. I won't bother with the original idea then. I prefer tried and true. Thats the good thing about this forum.
Old 03-02-2015, 09:02 AM   #74
I changed oil to TSC Traveller 10-40 and right away I have a quieter idle and fast idle.
No idea what oil the PO used but I sure like this so far.
Old 03-19-2015, 10:51 PM   #75
2 tank MPG so far= 11.5. No hwy miles of any significance.
Old 03-20-2015, 09:55 AM   #76
There are any number of "home" appliances that will work just fine in RV's, but bear in mind, none of them were designed to be bounced around day in and day out and stay together. The better quality RV equipment will. Especially important with anything that is holding fluids.
Old 03-23-2015, 04:05 PM   #77
Wood caricature of our bus, not finished yet.
Old 03-23-2015, 04:15 PM   #78
Chassis: I.H.
Cracks me up!! The note above the bus says that it has been resized! Looks great though. My grandkids would love it.
Old 03-23-2015, 04:17 PM   #79
5in long! ....
Old 03-25-2015, 07:14 PM   #80
FWIW, our bus has the hot WX package; 2 AC units, white roof, tinted windows and extra insulation.
Today it was parked in direct sun, all windows and doors shut all day. 1/2 the curtains were open. No AC or fans on. The rear of the bus was facing the SW.
Ambient high temp. was 78.8 with a slight breeze, at that temp. inside was 78.5.
I drank the Kool-Aid opus Skoolie Conversion Projects 176 06-03-2016 09:12 AM
Plan in works to fix 'Electric Kool-Aid Acid' bus lornaschinske School Bus News 0 03-16-2013 11:25 AM
15 kool buses for auction citrus co Florida racetearoffs2 Classifieds | Buy, Sell, Swap 2 02-12-2009 03:01 PM
Olde Skool update 7-7-07 KaptnKAOS Skoolie Conversion Projects 0 07-08-2007 12:42 AM
Old Skool's Got brake lights !!! KaptnKAOS Conversion General Discussions 16 06-26-2007 02:41 AM
