Old 01-08-2013, 01:49 PM   #201
lornaschinske's Avatar
Year: 1986
Rated Cap: 89
Re: El Tortuga...update 01-07-13!
Originally Posted by bansil
...added polyfoam foil crap ... oh and Lorna...I know your pain now...I have millions of little white styrofoam balls everywhere
Thermal breaks make such a huge difference.
I HATE that Perma R crap. We have to buy some more this weekend to do more to the interior walls. Not any choice really here. I'm going to have those lousy Styrofoam beads all over until we get the interior sealed up (soon, soon!). There's just so much static electricity too! Little Styrofoam beads stuck to everything including ME! I will just deal with it (and vacuum a lot). David's got the bedroom and toilet area furred out. The toilet area gets the last of the pink Foamular because it's such a small amount and I intend on using the freebie pegboard we have to cover the sidewall with. I need to buy some pegboard fittings. HD has a set of three baskets that hook into pegboard. I need something to hold our tooth brushes (screwdriver holders), David's electric razor (small basket) and a few things that are currently sitting on the vanity countertop. I need to cut and fit the toilet room insulation today.
Fulltime since 2006
Old 01-10-2013, 05:11 PM   #202
Moderator
crazycal's Avatar
Chassis: 3800
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Awesome. Did you skin the windows?
I'm hungry!
You Gotta Let Me Fly
Old 01-10-2013, 07:10 PM   #203
Nope CC, we wanted to keep the ventilation so all windows will lower to the non installed sill pc.
I just needed to insulate the damn microwave ovens called "black windows" even at 19* the sun hitting the blacked out windows was hot as heck.
Since we both hate or loathe...nagh we hate cold weather the warming effect will be so not missed in the other. 8 months.
Old 01-14-2013, 09:24 AM   #204
Added loose insulation and then filled in with 4 pc of poly crap(back wall gets really hot/cold being single layer sheetmetal
covered with 3/8 plywood
I forgot to take pics of the installed verticle pcs to match the bottoms of the bunks and got first coat of poly on them
Also scraped off paint for natural light,will cover in very heavy curtains
Old 01-14-2013, 09:39 AM   #205
Year: 87
Chassis: International s1700
Engine: 6.9 internatiional
Re: El Tortuga...update 01-14-13!
its really coming along.
proconsul100 is offline   Reply With Quote
Old 01-14-2013, 09:44 AM   #206
Thanks, when I get this 12 feet wrapped up...I only have 23 more feet
6 more months...gotta crack the old whip
Old 01-14-2013, 11:15 AM   #207
Your heavy drape idea will help a lot. For those times when you still want light try covering the window opening with a piece of clear polyvinylchloride (thin version of convertable window material) secured by the magnetic strips found in old frig door seals. This provides a nice thick layer of trapped air and slows heat loss/gain. Jack
Old 01-18-2013, 04:29 PM   #208
spent some time this afternoon in the bus after going to wally world and lowes this morning...and yeah we got between 8-12in of snow last night,luckily we already had 4in of standing water from 4 days of rain to soak up the snow
any ways
I bought some carpet and glue today(didn't really intend to it just happened)
I was comparing some samples from last weekend,when the guy said "you need some help?"
It nasty and snowy and I only need about 4 ft of this 15 foot wide carpet,but I don't want to put it on top on the snow and salt
(we had picked out a color that came in 15 ft width,figured I could get 4 feet and then slice it down the middle and have 2 pc to fit all 4 walls in the bedroom.)
The guy at lowes said "hell I can cut it 2ft wide and we can roll it short side, so it can be put in your truck and not on top with snow"
okay cool...he said since it's a new roll he would cut it alittle long for me so it will be square,
So I needed 22.50 in and he cut it at 32-ish.
He went to roll out next 2 ft and there was a dirty spot about 18in dia at the end, i pointed it out and he said "can you use whats left on that 2 feet?" I said if it's cheap
he smiled "well...I cant sell that"...so 7 feet or so later(i havent measured it yet) I had my 2 pc of carpet that equaled 4 feet!!!!!
some glue; a cheap trowel and I was on the road
first pc cutting to fit...exactly what in the hell is best way to cut this crap?new razor, so so pulls yarn.Kitchen shears(dont tell Lisa)..my hand is sore and sooo,sooo....a combo of both seems to work best.
first pc up
some more
pic of look im going for
glue
check out wrapped price since it was "damaged" it got it cheap $6 a foot normally about $12 a foot
.........24 dollars almost a steal,but I paid for it
more tommorow
Thumbnails...this is new to me...but bandwidth friendly..if I did it right
Old 01-18-2013, 05:58 PM   #209
Year: 1986
Rated Cap: 89
Sharp razor, cut thru the jute backing from the backside of the carpet using a progressive "sawing" method. Use scissors to cut the "stringy" stuff (looks like plastic ribbons). Change blades often. This is the method that I have found that works best for me. I dislike cutting carpet! I don't care much for carpet either. I'm going with Commercial Tiles on the rubber floor once we finish the interior.
Then I'm going to put some floor runner carpet down as "throw away" rugs. When they get too dirty, I throw them away. HD has some "binder" material that you glue to the cut edges for a finished edge (kept next to the rolls of cut-to-length carpet runners).
Fulltime since 2006
Old 01-18-2013, 06:14 PM   #210
GreyEagle's Avatar
Re: El Tortuga...update 01-18-13
Some guys get all the luck....... Congrats...
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Old 01-28-2013, 05:59 AM   #211
busy working on the bus this weekend
I got the bikes mounted inside
mounted a tv also,I had to modify bracket to allow acess to the plugs and also mounted a 3rd bolt to secure it
worked on the back walls so we can lean on them etc
still need to poly them tho'
Still need to make a dust cover for tv and then a velcro strap to hold it against wall when traveling
Old 01-28-2013, 09:00 AM   #212
syke's Avatar
Chassis: All American RE
Re: El Tortuga...update 01-28-13
Looking sharp Bansil.
I really dig the tv mount and the wood work. Keep up the strong work!
Ryan
Bluebird All American RE: Great White Buffalo (gone but not forgotten)
Our build thread: viewtopic.php?f=9&t=10065
syke is offline   Reply With Quote
Old 01-28-2013, 09:23 AM   #213
Accordion's Avatar
Year: 1973
Engine: CAT 1160 V-8 Diesel
I like the pine wood. Is that 3/4 tongue and groove?
Best Home Yet - Strong Command Center --- viewtopic.php?f=9&t=10764
Accordion is offline   Reply With Quote
Old 01-28-2013, 09:44 AM   #214
Thanks Syke
Thanks; nope it's cheaper 1 x 4 furring strips
Old 01-28-2013, 11:38 AM   #215
browncrown's Avatar
Rated Cap: 79 at Birth
Everything looking VERY nice Bansil...looks like you've made a lot of progress
BC
My Conversion Thread: https://www.skoolie.net/forum/viewtopic.php?f=9&t=3065
browncrown is offline   Reply With Quote
Old 01-30-2013, 02:05 PM   #216
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
Wow.. Kayaks and fishing poles and now bikes. Very active lifestyle. Cool. I love the TV set up.
Linda Kay
trans·mog·ri·fy Verb: Transform, esp. in a surprising or magical manner.
Shadoll is offline   Reply With Quote
Old 01-30-2013, 02:30 PM   #217
fishing (with bobbers),kayaking (on quiet rivers and lakes nothing above classI rapids dont want to spill our beer ) and mountain biking (on flat ground now)....kinda look like posers
I was actually looking at the 3 wheel bikes...but they are too wide for back door....but...they have a picnic basket and a bottle of wine holder now that would be nice
Old 01-30-2013, 02:35 PM   #218
browncrown's Avatar
One should always eat right and drink plenty of fluids when engaging in outdoor exercise (or indoor for that matter)
BC
Old 01-30-2013, 02:46 PM   #219
Old 02-07-2013, 09:36 PM   #220
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
Gotta have my wine.....
Linda Kay
The Voyages of La Tortuga bansil On the Road | Travel, Trips, Camp Sites, Tailgates 8 09-21-2013 10:12 AM
Screw This Town!!!!! (Updated AGAIN) lapeer20m On the Road | Travel, Trips, Camp Sites, Tailgates 10 12-24-2009 04:18 PM
Space Saving A/V Entertainment Idea (UPDATED) slov Conversion General Discussions 9 02-05-2009 02:31 PM
Smoke 'em if you've got 'em!!! (Bus Burnouts) (UPDATED) phillbus914 Everything Else | General Skoolie Discussions 1 09-18-2008 01:47 PM
Updated pictures in the Gallery Bidin Time Skoolie Conversion Projects 2 06-08-2006 08:04 PM
