Old 01-14-2015, 03:08 PM   #1
Raw Slaw's Avatar
Winter Storage/battery charging
Hi all,
We're here in central VA and it's getting a bit cold. I recently had both of my 12 volt batteries fully charged, and I'm wondering about what we should do for winter storage. The bus will not be moving for the next year or so.
We have a Black and Decker "smart charger" that can do a float charge, and I"m wondering how many amps I should charge at (I'm guessing 4) and if I should bring the batteries into the basement, on the porch, leave them in the bus, etc. Thanks for reading and I appreciate any advice about keeping my bus healthy while stationary.
Raw Slaw is offline   Reply With Quote
Old 01-14-2015, 06:41 PM   #2
opus's Avatar
Chassis: All-American R/E
If you bring the batteries in that will make it hard to start the bus once a month or so. You could disconnect the master switch and leave them there with a "battery minder". However, I have been told that those trickle chargers are no good for batteries.
Glad I could clear it up for you, lol.
Old 01-14-2015, 10:35 PM   #3
Raw Slaw's Avatar
Awesome, thanks. Our bus is on the street, so we'd have to have a giant extension cord running from the house and it would make us pretty conspicuous, so I'll just have to keep them close by.
Old 01-20-2015, 04:57 PM   #4
Hank's P-O-S's Avatar
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
I would install a master switch to disconnect the batteries.
As long as you have good batteries you would be surprised how long they will stay charged for. I had an old 650cca interstate battery a friend gave me after he scrapped his farm car. This battery was manufactured in 03, after leaving it on my garage floor (-40 sometimes) all winter it still started a '99 VW passat(?) and it was a v8.
The moral of the story is.... If the battery is disconnected it will be fine. I would also recommend hooking up 1-2 1.5 watt solar battery maintainer. Just leave them on the dash, avoid H.F. Apparently there is no diodes in those ones.
Hank's P-O-S is offline   Reply With Quote
Old 01-22-2015, 10:38 AM   #5
bubb, the real one's Avatar
Coachwork: Thomas/International
Chassis: 3700
Engine: 7.3
If you decide to use a solar battery maintainer you will need at lest 5 watts per battery, probably better to have 10 watts, any less and it will not keep the batteries topped off.
If you get a 10amp plug in battery maintainer you can just plug it in every week or two, get one with a quick connect that you can leave connected to the battery all the time,
Even if you decide just to start the bus every week or three you still need to experiment to make sure whichever method you use is working, to do this just charge as much as you think is necessary, let the battery set for 6 or more hours without being charged and then check the voltage, 12.6 or 12.7 is great, 12.5 is ok, anything less means you need to charge more the next time, then you will also need to see how fast your batteries discharge and this also takes some experimentation with a volt meter.
bubb, the real one is offline   Reply With Quote
Old 01-22-2015, 10:44 AM   #6
Just throwing this out there in case anyone is needing batteries. Rural King has Exide-made batteries on sale for $75 for a group 31 size. I bought mine there and am happy months later.
I start mine about every two weeks and drive it around the pasture a bit.
Starts up quicker than my new subaru.
Old 01-22-2015, 10:55 AM   #7
frank-id's Avatar
keeping any battery fully charged
The method that works great is to connect any charger to a basic clock timer, available for less than $10. Set the charger at about 20 amps. Set the timer to 6 hours on, set time to 6 hours off. I have been using this method for many years. My Crown is always ready to start. Frank
frank-id is offline   Reply With Quote
