Old 01-15-2015, 07:38 AM   #1
timbrass's Avatar
Location: Henley-on-Thames, United Kingdom of Great Britain and Northern Ireland
Rated Cap: 29
3 Point Seatbelt - how to fix
I have a Bostrom Talladega 915 seat that has a 2 point lapbelt which is not legal in the UK - it has to be a 3 point belt (with the belt coming from a high mount point, over the chest to the connector and then back over the lap.
Has anyone else tried to fit a 3 point belt? I either have to fix the third point near the head of the seat - will strip off cover to see if there is anywhere secure to mount it, or will have to mount on the frame just behind the driver - I was going to take out two of these bolts and fabricate a bracket that presents a flat surface to bolt the third point (the belt reel)
Anyone else tried fitting a 3 point belt?
My Build site is https://schoolbusconversion.net
timbrass is offline   Reply With Quote
Old 01-15-2015, 08:07 AM   #2
All new buses have a three point seat belt mounted exactly like you are proposing.
I would think the parts required to mount a 3-point belt would be available Blue Bird, IC, or Thomas.
I know new seat belts are available. I can't imagine why the mounting hardware wouldn't be available as well.
cowlitzcoach is offline   Reply With Quote
Old 01-16-2015, 11:49 AM   #3
timbrass's Avatar
Rated Cap: 29
I'm going to get this bracket made up by my local Blacksmith and attach the bus frame. Will grind off the top two existing bolts - the nuts are welded on! and replace with M12 bolts
The bottom hole will hold the inertia reel and the top hole the double=back bracket.
Old 01-26-2015, 04:05 PM   #4
timbrass's Avatar
Rated Cap: 29
This is the mounting I made to fit a 3 point belt. I used 5mm steel rather than 4mm.
