Old 01-07-2015, 06:05 AM   #21
insurance is always fishy!
Old 01-07-2015, 06:48 AM   #22
Coachwork: ward
Chassis: international
Engine: dt360a
please tell us the name of the new insurance company and what are their requirements.
thanks
claydbal is offline   Reply With Quote
Old 01-07-2015, 07:06 AM   #23
I only know of two that will insure a school bus. Progressive and GMAC. Progressive won't insure it if its an RV, and GMAC won't insure it until it is.
Old 01-07-2015, 11:34 AM   #24
Zephod_beeblebrox2's Avatar
Year: 1994
Coachwork: carpenter
Engine: 466dt
Rated Cap: 59
It's insured via Progressive as self-done bus motorhome conversion. At the moment, liability only BUT when I've completed it, I'll raise the coverage. If anybody asks, I paid a conversion company to do it ;) I found from a conversation with allstate that done yourself, they won't touch it. Bought as a motorhome, they will. Weird!
Zephod_beeblebrox2 is offline   Reply With Quote
Old 01-07-2015, 12:10 PM   #25
Originally Posted by Zephod_beeblebrox2 View Post
The basics of my in bus toilet!
The in bus toilet cubicle!
Based on a few build/advice video's I have watched, you will want to bring the lip of the bucket up very close to the bottom of the seat... I think that things may escape otherwise.
Nachowarrior is offline   Reply With Quote
Old 01-07-2015, 12:38 PM   #26
Good luck. Hopefully Progressive works out. Lots of folks get cancelled after a few weeks. I take it you did the online form?
Old 01-07-2015, 07:39 PM   #27
Year: 1994
Engine: 466dt
Rated Cap: 59
Things like Dragons, Orcs, Trolls, women with hairy armpits and Ogres?
Seriously... That's all covered - literally - with cat lit.
Old 01-07-2015, 07:43 PM   #28
Year: 1994
Engine: 466dt
Rated Cap: 59
I did the online form then went to see an agent locally. Told him the story and showed him State Farms letter of the 23rd stating insurance would lapse on the 13th then the letter dated the 26th with the refund (which presumably means the insurance was null at that point) but which I did not receive until yesterday.
The agent said that he had about 30 companies to deal with and could sort out any problems but then though he was a "progressive" agent, he was independent and not tied to Progressive.
Old 01-10-2015, 08:30 PM   #29
Year: 1994
Engine: 466dt
Rated Cap: 59
Right now I'm working on removing the rotted plywood panels somebody put on the floor. Under the panels is a tarry paper type thing under which is galvanized steel. The paper stuff does not look like a carpenter thing.
The panel removed was rotted by seepage from the door on one side and by a leaky water heater on the other.
By the door will be the toilet. On the other side will be the bathroom. I think under those two areas, I might put plastic planks.
Old 01-19-2015, 10:15 PM   #30
Year: 1994
Engine: 466dt
Rated Cap: 59
I've replaced the front two passenger windows with aluminum paneling and replaced the remaining plexiglass window with a transplanted window.
Then... I took the bus to the store and bought some donuts.... First run in 3 weeks. It was amazing how far the wheels had sunk into the sandy soil in just 3 weeks!
Old 01-20-2015, 04:17 AM   #31
Yeah I move mne every couple weeks as the sandy cow pasture I keep it in starts to give way under the tires. I suppose I should get some boards to park on.
I need to tag mine still.
Any pics of the paneling you used to replace the windows?
Old 01-20-2015, 07:13 PM   #32
Year: 1994
Engine: 466dt
Rated Cap: 59
Old 01-21-2015, 08:06 PM   #33
Year: 1994
Engine: 466dt
Rated Cap: 59
[IMG]
There - a pic with a real camera
Old 01-25-2015, 02:35 PM   #34
Year: 1994
Engine: 466dt
Rated Cap: 59
Whoever suggested furring strips was brilliant. I just bought some packs of them and they're cheaper than the 2*2 I bought before and dry nor mushy
Old 01-25-2015, 06:49 PM   #35
Year: 1994
Engine: 466dt
Rated Cap: 59
I've been working on her this weekend
Old 01-25-2015, 07:08 PM   #36
Cool. Glad youre maintaining progress. Hows your weather been up there?
Old 01-27-2015, 05:21 AM   #37
Year: 1994
Engine: 466dt
Rated Cap: 59
Weathers been OK. Close to freezing at night but warm enough to work outside in the day without a sweater.
Old 02-22-2015, 09:30 PM   #38
Year: 1994
Engine: 466dt
Rated Cap: 59
The bath is almost fixed in place. I still need to put the outlet pipe but its almost done. The mount for the bath is done. Maybe some moving around so the hole misses chassis members.
Old 02-24-2015, 07:05 PM   #39
Year: 1994
Engine: 466dt
Rated Cap: 59
Hmm... I sealed a lot of roof leaks but it seems a couple remain.
Solution - caulk the suspect areas then go along every roof seam with aluminium tape. That stuff lasts forever and shouldn't crack. Finally, its paintable so I can happily paint over it.
The bath was a waste of time. No way could I make it fit. Aside from being too long, the limited movement I had was insufficient to allow me to move the drain out of the way of a chassis member and the low ceiling means raising it was not possible.
Old 02-24-2015, 07:07 PM   #40
Chassis: TC2000 FE
Engine: 190hp 5.9 Cummins
Nat
have you tried to move the door to the middle of school bus kimberlink Conversion General Discussions 21 12-31-2021 10:00 AM
*Sold* Converted Bookmobile for sale in Middle Tennessee josetann Classifieds | Buy, Sell, Swap 14 10-20-2011 08:02 PM
Rear exit door on a full sized blue bird SCARECROW Conversion Tutorials and How-to's 1 05-29-2011 08:55 PM
