Old 12-30-2014, 05:19 PM   #1
Talking Roll up Door??
Anyone ever try putting a roll up door on the back of a Bus??
MadFrogPB is offline   Reply With Quote
Old 12-30-2014, 09:11 PM   #2
I considered the idea for my future toyhauler, but decided against it because I'd rather have the back door fold upwards to double as an awning. But I don't see why a rollup door wouldn't work.
https://www.skoolie.net/forums/showthread.php?t=9883 - 7.3L 4x4 Shuttle Bus Toyhauler conversion
headinthetrees is offline   Reply With Quote
Old 01-01-2015, 08:10 AM   #3
Coachwork: MertoTrans
Chassis: Ford E-SuperDuty
Engine: 460 Ford
Rated Cap: 4
I would think the required headroom for a rollup door would be a major problem.
davidshelton is offline   Reply With Quote
Old 01-01-2015, 08:13 AM   #4
Thinking more of the commercial metal kind that rolls up. Not the garage door style with tracks..
Old 01-01-2015, 10:17 AM   #5
S1.
S1.'s Avatar
Commercial applications such as Semis and U-Haul trucks have flat roofs. A typical school bus roof is curved, so to make it work without eating up precious head room would require a roof raise, or if not, some serious roof mods.
S1. is offline   Reply With Quote
Old 01-01-2015, 10:47 AM   #6
NO more like these;)
http://www.motorcitydoor.com/firedoors.php
Old 01-01-2015, 06:51 PM   #7
S1.
S1.'s Avatar
Ah... OK... now that's thinking outside the box. No pun intended. LOL
Old 01-02-2015, 06:17 AM   #8
Engine: 460 Ford
Rated Cap: 4
99% of commercial rollup doors have the "roll" to the interior. You still need about 18" or so headroom inside or outside. The fire-rated door looks expensive.
Old 01-02-2015, 08:13 AM   #9
I have access to 3 different sized units (12, 6 & 4 ft wide) used. I may just replace the panels on the back of the bus, the doors new, the right side is toast.
Wanted some feedback & thoughts about it...
I own a Portable Paintball business (www.madfrogpaintball.net) the bus is replacing our 24ft trailer & the back is the storage/garage area. The door will work but I'm looking for options...
Pics @ Instagram MadFrogPB
Old 01-02-2015, 08:15 AM   #10
Thx for the feed back so far, it helps it really does
Old 01-05-2015, 05:16 AM   #11
Coachwork: corbiel
Chassis: Ford E350
Engine: 7.3
Rated Cap: 10 people&handicap
No reason why it should not work. My dad put one in the side of his small garden shed that was only about 6 or so feet high, . I could check with him where he got it. very light weight.
woodsong is offline   Reply With Quote
Old 01-12-2015, 05:09 PM   #12
RevBill's Avatar
Coachwork: - Still Shopping -
Chassis: - Going Medium/Large -
Engine: - DT466 Desired -
.. check out the ones used on rescue vehicles/firetrucks (can be pricey) .. fair warning though, they are not insulated nor weather-proof/water tight in most cases .. not sure if other commercial units are either .. good thoughts though ..
Chance favors the prepared mind. - L Pasteur
Luck is the residue of good planning. - B. Rickey
Travel is fatal to prejudice, bigotry, and narrow-mindedness ... - M. Twain
RevBill is offline   Reply With Quote
Old 01-18-2015, 09:46 AM   #13
Engine: Int DT466
Rated Cap: 48
I put a tilt down door that doubles as a loading ramp Charlie
Chasgoat is offline   Reply With Quote
Old 01-18-2015, 12:13 PM   #14
REDD's Avatar
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 2 ATV's and friends
Those style doors would be anchored to a building... how much pounding would they take bouncing up and down the road?
Chasgoat: How long is your ramp, does it go up to the curve in the roof or below the lights?....or did you drop the floor or raise the roof? how much of a pitch is the ramp?
Thanks
REDD is offline   Reply With Quote
Old 01-18-2015, 02:32 PM   #15
If you could direct me to pics of a ramp setup Plzzzzzz
Old 01-25-2015, 04:40 PM   #16
gizmoq's Avatar
Year: 1978
Chassis: Lifeguard
Engine: 366 Chevy
I can't take credit for the conversion, but I did rebuild it to withstand higher loads. My back door is 7 1/2' x 7 1/2". It uses 2 3" hydraulic pistons bolted underneath the dovetail. Requires no power or hydraulics to open, but needs engine and pump running to close.
http://www.skoolie.net/forums/showpo...8&postcount=13
gizmoq is offline   Reply With Quote
