06-28-2018, 08:51 AM
#401
Chassis: Blue Bird TC RE 3904, Flat Nose, 40', 277" wh base
Engine: 8.3L Cummins ISC 260hp, MT643, 4.44 rear
Rated Cap: 84 pax or 1 RV; 33,000lbs
Your CAC and my CAC are not the same. My CAC is a Common Access Card and gets me on the base to my bus but does not affect fuel mileage as it only weighs a few grams. I suppose with the lanyard and holder it could be as much as 3 or 4 oz.
06-28-2018, 08:55 AM
#402
Charge Air Cooler. How do I know? I had to look it up too!
06-28-2018, 09:00 AM
#403
aka; Intercooler
BTW...my local diesel techs put a factor of 10-15% improvement in power AND mpg's for an intercooled engine over non-cooled.
06-28-2018, 09:14 AM
#404
good call on checking the turbo cooler. evben pinhole leaks mean lost boost.. same with exhaust manifold gaskets.. esp on RE busses where you may never hear a small pre-turbo exhaust leak..
-Christopher.
06-28-2018, 09:24 AM
#405
I was military and I work on a military base. I purposely refuse to speak acronym but I also didn't know that one.
06-28-2018, 09:31 AM
#406
BTW...
if anyone needs a top of the line CAC/Charge-Air-Coooler/Intercooler...
I have a Behr C9415 I can let go of cheap. Maybe a hundred bucks + shipping or pick up in Houston. Came out of a taco truck (P-30) and is plenty adequate for 3.9 to 5.9 Cummins.
Can provide pix & measures if interested. Just PM me.
06-28-2018, 09:35 AM
#407
Originally Posted by Tango
aka; Intercooler
Aside from being a$$holes why can't the bus industry just call it that then?
06-28-2018, 10:22 AM
#408
Chassis: AARE
Engine: 3116 Cat 250hp
Sorry, came out of the trucking industry, just assumed everyone knew what it was. I also hate acronyms, don't know what I was thinking.
06-28-2018, 10:35 AM
#409
Originally Posted by somewhereinusa
Just to avoid the confusion, I meant the engineer that came up with the name in the first place instead of using intercooler.
06-28-2018, 12:18 PM
#410
Chassis: TC RE
Engine: 8.3L
I knew what he was talking about after 45 years in trucking. Trying to learn bus terminology.
GaryC
06-28-2018, 12:34 PM
#411
Is there a difference?
06-28-2018, 01:32 PM
#412
navistar calls them 'Aftercooler'.. the DT-360 is a 'Diesel-Turbo 360 cubic inch', the DTA-360. is a Diesel-Turbo-Aftercooled 360 cubic inch'.... but later they dropped the designation as they were all 'Afrercooled'.. the label DT-466 on the side of a bus could mean either.. (you just had to look through the grill to see.).. grrr.. manufacturers and their designations..
06-28-2018, 01:43 PM
#413
Upon further thought, I'm not even sure I want to blame the engineers. A larger part comes from the marketing weenies.
06-28-2018, 02:11 PM
#414
Chassis: TC RE
Engine: 8.3L
Yes, bus terminology. hehe
GaryC
08-05-2018, 03:45 PM
#415
Chassis: AARE
Finished the slide outs for the pantry. Well almost, as usual I have to put doors on, still haven't got any of the other doors done but, why rush into things. Anyway, I gained a ton of space over the temporary drawer thing I had.
This is looking from the kitchen
Looking from the bathroom, some shelves are accessible from either side.
08-05-2018, 06:06 PM
#416
Rated Cap: 34
Nicely done.
Are those standard drawer slides, or the heavy-duty version? And how much do you think that whole door/drawer weighs?
08-05-2018, 06:28 PM
#417
Chassis: AARE
Originally Posted by plfking
Nicely done.
The slides are 100# a pair, I added a third one. There is a slide top and bottom sideways to eliminate sway when extended. The shelf weighs 40# and a case of water about 35#. I think the third slide is enough margin of safety.
08-05-2018, 07:23 PM
#418
Rated Cap: 34
I think you'll be fine.....always good to overspec a little.
And thanks for the info. It will come in handy when I start building my interior.
08-05-2018, 07:24 PM
#419
Nice design. The top and bottom slides will add a lot of stability. Jack
08-06-2018, 06:56 AM
#420
If the slides are top and bottom, where's the third one?
