Old 05-29-2014, 05:04 PM   #1
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
2003 Amtran/International battery cables
Ok, not necessarily a drivetrain/mechanical question, but more along the lines of electrical. I swapped out the two (dead) coach batteries for a single 8D. The two batteries had their positive and negative terminals bridged, with leads running in along a 2d ground cable. I'm thinking these were the glow plug cables, but I'm not 100% sure; the wait light no longer lights. And if they were the glow plug cables, would my local truck parts shop have them for single battery systems?
I'll try to have some photos of the cables and current battery set up tomorrow. Can't do the old batteries, because they've been turned in.
Hey! That's not an RV, that's a school bus.
Well thank you for noticing, Captain Obvious
Captain Obvious on deviantArt
Scooternj is offline   Reply With Quote
Old 05-29-2014, 06:37 PM   #2
opus's Avatar
Chassis: All-American R/E
Re: 2003 Amtran/International battery cables
That doesnt make sense to me. Get some pix.
Old 05-30-2014, 03:28 PM   #3
Chassis: B3800 Short bus
Rated Cap: 36
Are there smaller gauge wires connected to the bridge cables? My international had some necessary wires connected to the bridge cables and it won't start without em.
Old 05-30-2014, 06:33 PM   #4
Scooternj's Avatar
Engine: T444E/AT545
Rated Cap: 75
Yes there are. I take it they'll need to be either spliced into the main cables or terminal ends applied and tied into terminals?
Old 05-30-2014, 07:23 PM   #5
Rated Cap: 36
Yep! I did the same to mine. I think they provide direct power to the ECU or some other computer controller. Pretty important. I just clipped them off of the large gauge wire and put 5/16" terminal rings on them and connected them to the appropriate battery terminal. A trivial job.
Old 06-01-2014, 06:55 AM   #6
Scooternj's Avatar
Engine: T444E/AT545
Rated Cap: 75
That was it. Wired up the connectors yesterday, and the bus fired up.
1997 AmTran International DT466 crazycal Skoolie Conversion Projects 158 07-21-2017 08:36 PM
1998 Amtran International loganmeckley Classifieds | Buy, Sell, Swap 0 11-12-2013 12:22 PM
1996 International 3800 Amtran jackson7209 Classifieds | Buy, Sell, Swap 0 10-15-2013 09:09 AM
Battery cables somewhereinusa Electrical, Charging and Solar 6 02-25-2013 07:21 PM
House battery Cables???? JonCBrand Conversion General Discussions 3 02-22-2005 08:05 PM
