Old 02-25-2012, 05:58 PM   #101
Re: The Hubbly Bubbly Bus!
Since it has only run for a short time with it's condition.
I would just pull the plugs(mark wires) and let them dry out....the "tip" and the "bent" pc are what creates the spark between them.
Follow this...when the ignition "says" to fire,a strong electric current travels through. The plug wire to the spark plug.
Current is always looking for easiest way to ground.
Normally this is thru the plug to the tip,it then must "arc/spark" across the gap to the "bent" metal pc and then it will ground to the threads of the spark plug,to the head and end up at the -side of the battery.
If your plugs are wet with gas,it will not spark or fire as elcectricity will travel up the porcilen to the metal thread are,bypassing "the gap" no spark.
Just dry out the plugs(stick something over/in plug holes so no dirt etc.gets into the engine..save the $ for new plugs right now.
I am trying to explain simply how this works.I am trying to help...not be mean
Old 02-25-2012, 06:00 PM   #102
lornaschinske's Avatar
Year: 1986
Rated Cap: 89
I would simply add a 2nd (regular)starting battery. We crank ours off a single battery but ours is turned up right and cranks right up.
Fulltime since 2006
Old 03-20-2012, 07:49 PM   #103
update?
itsme1738 is offline   Reply With Quote
Old 04-02-2012, 08:50 PM   #104
keep us posted!.....i was starting to wounder about you guys,i didnt know if you were still in boulder or not,still at the same place?
Old 04-03-2012, 03:22 AM   #105
There has to be something else that is not in good shape if something like a 1000CA group 24 battery won't start a 390 ford gas engine... and it is a long list.
Old 04-05-2012, 11:05 PM   #106
Coachwork: ElDorado
Chassis: Chevy P30
Engine: 7.4 liter 454 Chevy
Rated Cap: 24
per chevy49 if you still have problems turning over the bus with all that you replaced?
Battery cables were replaced and engine is grounded really good?
With a 1000 cca battery you should be almost able to drive down the road on cranking the starter.
Did you do the distributor check to see where the number one cylinder terminal is being pointed at by the rotor when the cylinder is in the firing part of the stroke?
Bullwhacker007 is offline   Reply With Quote
Old 04-24-2012, 08:59 PM   #107
I don't know all the details...but if your ducks are in a row....call the local tv station..and find someone that knows what Fawk is going with the bus....dang its old skool gas and carb'd...any 4x4 shops around?give them a call...this sucks and I do feel your pain.
I would love to fly out(beyond broke tho') and help you.
I feel saddend...cause I feel ya'll have been screw'd by folks that ain't worth a shiatt...
Keep your heads up...best case is you have each ther....good luck
Old 06-30-2012, 12:12 AM   #108
Year: 1986
Rated Cap: 89
Has anyone heard from these folks? Just wondered about them, the bus and if they were okay.
Fulltime since 2006
