10-30-2011, 02:07 PM
#41
Coachwork: - Still Shopping -
Chassis: - Going Medium/Large -
Engine: - DT466 Desired -
Re: The Hubbly Bubbly Bus!
.. good to hear from you guys .. glad you are okay .. you'll get everything sorted out I am sure .. you are surely on one heckuva an adventure ..
Chance favors the prepared mind. - L Pasteur
Luck is the residue of good planning. - B. Rickey
Travel is fatal to prejudice, bigotry, and narrow-mindedness ... - M. Twain
11-02-2011, 11:22 AM
#42
Year: 1986
Rated Cap: 89
Rats? Probably not there anymore. Close it, fill with water and flush (you might get a pumper truck to suck it out but I'm not sure if there's a nest of some sort in there)... if things are thawed up there. Your cold weather is passing thru here now. Tonight it is supposed to hit 27 for the low. Yuk! Guess I will plug in the heat tape we got wrapped around the tank valves on the Class C tonight. We learned in S GA that they DO freeze, contrary to what RVers have been telling me for years. Replacing a broken black tank valve is not fun!
11-02-2011, 04:57 PM
#43
Year: 1986
Rated Cap: 89
Originally Posted by MasterFeather
Problem is that the tank is already full....eeeewwww. And it is not draining at all. Not a drop. So whatever is in there has done a great job of damming it up. Suppose the pump truck idea aint a bad one!
Sounds like it's either the pump truck... IF they will or can or.... a small shovel to get at least part out... yuk! I deeply feel for you if it's the latter. But one day... in the future... maybe far... far... FAR in the future, you will look back at this and laugh and say it was an adventure. Better get it done during the next "warm" spell. I don't know about Colorado, but we are supposed to be getting another wave of freezing temps by the end of the week.
11-02-2011, 05:52 PM
#44
maybe you can run a plummers snake up into the discharge and into the tank, roto-rotor type, but just a hand crank type, also if you think its frozen can you park in a garge over night where its warm? with the tank full ridex may still work, it will start heating up.
good luck
keep us posted
11-02-2011, 06:58 PM
#45
Engine: 3208 na boat anchor
Running a snake up the discharge sure sounds like a sh*tty job. BTDT.
11-03-2011, 07:19 PM
#46
11-13-2011, 06:24 PM
#47
Year: 1986
Rated Cap: 89
And you don't have to do something that you really didn't want to... in the snow or sleet!
Our Mansfield Sanitary 910 is really old (came out off a 1970's era camper... Mansfield Sanitary changed their name to Mansfield Plumbing in 1976 ) and it doesn't have that valve. It's just the foot valve. I like the foot valve. Unfortunately we have gotten so used to it, both my daughter & I try to "foot flush" standard toilets when we use one. Talk about feeling silly.....
11-14-2011, 10:20 AM
#48
Year: 1986
Rated Cap: 89
Sounds like you have an old marine toilet.
11-14-2011, 08:11 PM
#49
Year: 1986
Rated Cap: 89
... The site I found about these things says they can be used as either an independent porta-potty or they can be hooked into a tank for an RV. Also, they can be made to have their own water supply for flushing, or be hooked into the RV water supply like ours is...
So does that mean you can be boondocking and not need to use the 12vDC water pump and it will hold enough water for flushing and not use water from your potable water supply? If so, that is cool.
11-15-2011, 04:41 PM
#50
Year: 1968
Chassis: Ford F700
Engine: Ford 390
It would be rad to have a battery bank so we could boondock more easily. Or at least more conveniently.
11-16-2011, 02:59 PM
#51
Year: 1986
Rated Cap: 89
That's too much. We pay $350/mo here in Socorro. We have Cable with HBO, free Wi-fi, Water/Electric/Sewer. No deposit. We also don't get much snow! You do have to have your own bathroom here.
12-03-2011, 10:52 PM
#52
You're sure getting your share of adventure. Glad to hear that it's all worked out OK.
12-05-2011, 10:13 AM
#53
Engine: DT466/AT545
...He scoped out the bus and found out that our alternator is shot, so we now need to get a new one of those and a new regulator for the alternator. Got a price quoted at $75 to do that, so hopefully we can drum up that much soon.
That sounds like an amazing deal to get an alternator installed! You got lucky on that. With a 40 year old vehicle, you can expect frequent breakdowns until you have pretty much replaced every part that can possibly break. You might want to get a mechanic to go through the bus and give you a list of pre-emptive parts replacements you can prioritize based on cost. Especially those parts that bring the bus to a standstill in a possibly inconvenient time and place when they stop working.
This is the experience I've had with old vehicles. There are a couple years of frequent breakdowns and parts replacements, and then eventually it gets more reliable since I've pretty much replaced everything that is likely to malfunction.
02-03-2012, 01:52 PM
#54
u still stuck in boulder?.....maybe i can look at it
02-03-2012, 01:54 PM
#55
where at in boulder?
02-04-2012, 10:11 AM
#56
you may have a bad starter, Iv seen brand new ones pack up in less then a week, and rebuilds can crap out the same day you put them on.
good luck to you, hope to see you on your way soon.
gbstewart,
btw, thats w very nice offer itsme1738,
02-05-2012, 06:50 PM
#57
i was just reading their thread and saw they were in boulder and thought maybe i could help....about 40 min away ..... i had that same style bus some 20 years ago
02-07-2012, 09:55 PM
#58
i was in boulder today.....
02-08-2012, 12:23 PM
#59
to bad that you didnt here from them, Im sure that you could have helped out, as well as meeting a fellow skoolie
02-08-2012, 12:36 PM
#60
Engine: DT466/AT545
You might try sending a private message or email from the forum. They may not have a reliable internet connection where they are, and are therefore not able to check this website often. If you send something that triggers an email perhaps they may get it on their phone.
