Old 12-16-2014, 02:40 PM   #1
Coachwork: Blue bird
Chassis: Handy bus
Engine: 5.9 cummins
2002 bluebird cannot move as brakes are locked
I have a 2002 bluebird handybus. It is 32' has the 5.9 and Allison automatic 6 speed. The bus runs fine, the air pressures both front and rear build to about 110 psi. Today I attempted to put it in my garage for the winter to continue working on it since it's getting cold out, but when I started it and the air pressure built, the brakes wouldn't release. There is a red light on dash that comes on every time you press the brakes, I understand that is normal, but now I can't get that light to go off since the brakes won't release. The light even stays on after the engine is shut down and key is removed. It stays on until the batteries die.
Anybody out there have a clue what the heck might be going on.
Thank you!
SmokinJ is offline   Reply With Quote
Old 12-17-2014, 09:25 AM   #2
Re: 2002 bluebird cannot move as brakes are locked
first off SAFETY FIRST
sounds like your rear drums are stuck due to rust or water, the semi metallic drum linings can rust to the drums, mine does it a few times a year
do not skimp on this step!!!!
block all tires front and back, you do not want the bus to be able to roll over you!!!
once blocked, fire bus up and build air pressure, release brakes with park knob (just like you'll drive it)
grab a 3 pound sledge hammer and a pc of 1/2 or 3/4 dia metal rod about 12 inches long (an old socket extension can work)
crawl under bus, be careful the bus can move/jerk when brakes release
look at rear brakes and you can see the shoes, notice if the pads are still touching the drum, if they are set the rod on top of shoe so the end is against the shoe ->_i hit rod very hard and quick a few hits should "pop" it loose
repeat on the other 3 shoes (2 each side)
Old 12-17-2014, 05:41 PM   #3
Chassis: Handy bus
Engine: 5.9 cummins
Thank you for your reply! I will give that a try and go from there. It sounds like a logical answer to my issue. I hope it works! I will post my results.
Again, thank you.
Old 12-17-2014, 05:44 PM   #4
Sometimes just rocking back and forth will break the brakes loose. Like the man said, be safe!
Don and Mary
dond is offline   Reply With Quote
Old 12-17-2014, 09:38 PM   #5
opus's Avatar
Chassis: All-American R/E
I release the parking brake and jab the foot pedal to the floor and let go. That always brakes them free. Thats an old Eagle trick.
Old 12-18-2014, 06:01 PM   #6
I can't do that with my allison 545 slip-o-matic
Old 12-18-2014, 06:29 PM   #7
opus's Avatar
Ha, sorry, I meant to jab the brake pedal, not that go pedal. You hot rodder!
2002 Cummins 24v TheHobbits Cummins Drivetrain 9 03-12-2013 05:38 AM
1999 BlueBird International - Rear Brakes NilesSkoolie International | Navistar Drivetrain 8 03-04-2013 12:38 PM
351 motor locked up chev49 Mechanical and Drivetrains 1 07-11-2012 08:55 PM
1991 BlueBird TC2000 Hydraulic/Hydraulic Brakes Sticking C00LR Mechanical and Drivetrains 0 10-15-2009 10:11 AM
brakes locked up schoolsout Conversion General Discussions 2 11-06-2008 03:59 PM
