Old 10-05-2009, 05:30 PM   #1
Year: 1994
Coachwork: Ford
Chassis: Carpenter
Removing School Bus Letters
Just because I haven't seen another post on removing lettering on the side of a school bus, I thought I would provide my own 2-cents worth. I started out trying to scrape the letters off with a paint scraper. Eventually after much research I turned to a propane torch - and it works like a charm to remove that school bus information tattooed onto the side of a school bus.
so you know.
-the waste-not wagoneers
http://wastenotwagon.wordpress.com
waste-not wagon is offline   Reply With Quote
Old 10-06-2009, 08:31 PM   #2
Year: 91
Coachwork: ward
Chassis: ford
Engine: ford 6.6L diesel turbo
Re: Removing School Bus Letters
I used a heat gun from walmart to pull letters and decals from our rescue truck at the fire station. It worked well and didn't hurt paint. Be advised you can't pull and heat at the same time. Hot as hell!!
firemanbud343 is offline   Reply With Quote
Old 10-07-2009, 02:25 AM   #3
I have to ask, Were you using one of the Gloves on the pulling hand?
Sojakai is offline   Reply With Quote
Old 10-11-2009, 08:44 PM   #4
Year: 91
Coachwork: ward
Chassis: ford
For me,I did not use a glove because you can't grab hold of the letters very well. I just had to heat them up and time it right so not to heat my fingers up when I pulled! lol
Old 10-11-2009, 10:13 PM   #5
Should have used a glove. Those things are rated for High Temp after all. And don't you just requisition a new set when you have too?
Old 03-08-2014, 05:31 PM   #6
Engine: 3208 turbo Cat
Hey guys, I removed the letters with heat gun from Harbor freight tools, but there is adhesive left from the letters and tried all kinds of chemicals to remove but no luck, any ideas?
J
juliol is offline   Reply With Quote
Old 03-08-2014, 06:57 PM   #7
Chassis: Freight-shaker (Freightliner)
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
J
Spray it with wd 40 when it has some sunshine on it. I use it to remove adhesives from all kinds of stuff.
-Doc
Docsgsxr is offline   Reply With Quote
Old 03-08-2014, 07:05 PM   #8
Chassis: TC2000 FE
Engine: 190hp 5.9 Cummins
J
-Doc
When combined with plenty of elbow grease.
Nat
Old 03-09-2014, 02:49 PM   #9
opus's Avatar
Chassis: All-American R/E
Heat gun for the heavy stuff, diesel after that. Comes off easy.
Old 03-09-2014, 06:07 PM   #10
Chassis: B3800 Short bus
Rated Cap: 36
I found the goop came off fairly well with paint thinner. Put some on a rag, wet the adhesive, wait a minute then scrub with the thinner soaked rag.
Old 03-14-2014, 05:17 PM   #11
bapos's Avatar
Engine: DT466E/MD3060
Not sure if you have access to a hot water pressure washer.... But I know that the one I used when I worked at a rental company would take all the factory stickers off our equipment with NOOOOOOO problems. I know we use to rent a gas powered pressure hot water pressure washer that did ok.
I would think the wd40/hot sun and a scrapper would do most of it?
Old 03-22-2014, 12:05 PM   #12
lawman's Avatar
Coachwork: Thomas Premier
Rated Cap: 36
I just used the GF's hair-dryer to weaken the adhesive bond then gently pulled the letters off. Any residue was removed using Contractors Solvent http://www.de-solv-it.com/all-produc...ctors-solvent/ which also works very well on stubborn silicone.
lawman is offline   Reply With Quote
Old 11-11-2014, 10:11 PM   #13
Year: 2005
Coachwork: bluebird micro
Chassis: ford
Engine: not sure
I am removing my letters with a propane torch and a paint scrapper but the metal has "popped" out on me. I m nervous that I am hurting the metal. Also should Something so hot so close to the engine? There are some numbers just off the hood
Caitiholladay is offline   Reply With Quote
Old 04-30-2015, 08:46 PM   #14
thecrabshomestead's Avatar
Coachwork: Genesis International
Heat gun totally worked
Thanks everyone for the discussion here. We used just a paint scraper for the letters and it worked fine...and then we noticed the reflective tape wrapped all the way around =more tedious but necessary work I kind of like that kind though. Definitely wanted that off so we attempted it with just a paint scraper, no go. Then moved to the sander, took a long time. Came on to the forum and within minutes I had my conclusion, Use my stinking heat gun I just ordered on Amazon for $20 for heating up steel before placing over removed windows, and for a didgeridoo project ;) So from all of the posts in a nutshell:
Paint scraper & Heat gun..if that doesn't work go to diesel/paint thinner...then sand the rough spots.
We did take some paint off with the the paint scraper and heat gun while removing letters/reflective tape/school bus stickers on rear and front, but I planned on sanding it and then covering with Corroseal to convert/prime any and all rust. Eventually we will wash and paint it.
Do you all recommend using paint thinner all over it or just using primer before painting the bus? I have seen both comments but not sure which is preferred and why. Thanks all for the awesome advice!
Mocrab
https://thecrabshomestead.wordpress.com/category/tiny-house-skoolie/
thecrabshomestead is offline   Reply With Quote
Old 05-01-2015, 11:23 AM   #15
this is how it is done Son.
c_hasbeen is offline   Reply With Quote
Old 05-01-2015, 11:13 PM   #16
Chassis: Genesis
Now there is a man in desperate need of a heat gun.
Timelord is offline   Reply With Quote
Old 05-03-2015, 11:49 PM   #17
LMAO That is awesome. And probably way more efficient with time..although fire scares me lol
Mocrab
Removing those seats the_experience03 Conversion Tutorials and How-to's 35 01-04-2020 03:48 PM
Removing Vinyl Numbers/Letters lornaschinske Conversion Tutorials and How-to's 17 10-03-2017 09:16 AM
Blue Bird letters opus Skoolie Conversion Projects 11 07-21-2011 10:12 PM
Removing Floors pipsqueek Conversion General Discussions 3 10-04-2010 12:51 PM
Removing Rivets oldog12 Everything Else | General Skoolie Discussions 3 05-25-2007 10:45 AM
