Re: Air Ride anyone?
Doc, Sorry I didn't answer your question. 1. It will cost a lot unless you very craftfully design and build it yourself. At least find the parts. 2. Anytime you are messing with truck suspension, prepare to enter the world of the 3/4 impact driver,minimum. Or 1" if you can. It is dirty, dangerous work that will challenge your level of skill and determination. That stuff does NOT want to move! 3.Guys on TV shows just show the smooth easy stuff and edit the problems out. When you successfully remove the Ubolts holding your rear springs with a 1/2" drive ratchet, I want to see that TV show. Some things are best left to a real truck suspension mechanic. Good luck with air ride. It's a good plan.
