Old 12-10-2014, 12:33 PM   #1
Coachwork: Startrans
Chassis: Ford e-350 single wheel
Engine: 5.4 litre
Rated Cap: 12
portable a/c - heat
Anyone try the portable A/C units with the heat strip as the primary Heat/Cooling in your bus with generator/shore power? I have seen some people use the portable A/C units with good results but I can't find anyone who relies on the heat strip to heat a bus/RV/Camper.
I have seen RV roof top A/C units with heat strips but many say they are only good for cold mornings and chilly evenings and won't heat the camper and eventually burn out after a couple of all night uses.
My shuttle bus is the smallest 12 passenger unit they make, so I don't need a lot of heat or A/C. Mostly used for overnight ATV camping with my son and family.
leadsled01 is offline   Reply With Quote
Old 01-25-2015, 04:38 PM   #2
JDE
Engine: DD 6-71T
I've got a Whynter ARC-14SH that I've used a couple of times. My bus isn't sealed very well yet and has no additional insulation either. In the hot Tennessee summer the air conditioning didn't keep up very well. It was cooler inside the bus, but not by much. I used the heat function back in October of last year. It along with a small space heater worked reasonable well (68 degrees inside/35-40 degrees outside). I've got a 40' Crown, so with that size of bus, I'm thinking I'll need two units, no matter if I keep the portable unit, or ditch it and get two roof mounted units. My biggest issue with the portable units is the amount of space they take up and dealing with the intake and exhaust hoses.
JDE is offline   Reply With Quote
Old 01-25-2015, 05:13 PM   #3
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
I have one, it will only put out heat above 32 degrees, the closer to 32 it gets, the less heat it puts out.
Old 01-25-2015, 05:20 PM   #4
Chassis: Ford E-350
Engine: 351ci triton v8
http://www.amazon.com/Mr-Heater-MH18...r+heater+buddy These heaters are suppose to be amazing. They are highly recommended. They usually use those small propane bottles but they sell an adapter for a large propane tank.
Jandrew is offline   Reply With Quote
30 amp Portable Distribution Box chev49 Electrical, Charging and Solar 1 06-10-2012 01:02 PM
RV or portable generator? BUSBOZO Conversion General Discussions 5 07-11-2010 04:22 PM
Me Portable Palace turtle Short-Bus Conversion Projects 0 01-02-2010 11:07 PM
Portable air Conditioner davido Everything Else | General Skoolie Discussions 6 09-06-2008 08:39 PM
portable a/c units? The Wanderer Conversion General Discussions 4 05-26-2007 02:52 AM
