Old 04-06-2015, 08:09 PM   #101
246 miles on 18 gal fuel.
3 tank avg. is now 12.5 mpg.
I keep a volt meter plugged in to a 120v outlet and today while playing with my BF Onan I see high volts w/o load...150v at times!
I had just cleared some debris from the needle seat so she was a bit friskier than usual. I had to adj; the speed screw/gov. spring tension to get her back to the proper volts with and w/o a load.
Range is 132 w/o and108 with.
Keep an eye on your output, 150v is a bit rough on appliances.
dond is offline   Reply With Quote
Old 04-07-2015, 04:04 PM   #102
Bluebird Blue B
Old 04-07-2015, 06:22 PM   #103
Good to hear!
Outings are best when they go smooth lol
Isn't 132 high? I thought it was like 6% at 120v and 10% at 240v
.....I haven't googled(on tablet) just curious
By the way really like the stripes! Or stripe I guess wink,wink....breast choice
Old 04-07-2015, 06:28 PM   #104
I got the numbers from the Onan BF manual.
Old 04-08-2015, 03:43 AM   #105
Aren't manuals good?
Remember losing them before the internet? Have to mail the company and wait 6 weeks or more for a new one to arrive
Old 04-08-2015, 07:56 PM   #106
Our BB has 4 ballast weights, all 4 are behind the rear axle. I removed 3 of them.
They measure 6in. thick, 8in wide and 28in long. That makes a combined girth of 34in x 28in x 6in. They are steel plates welded together and have a 1/4in thick support frame.
I am able to lift only one end of these and I'd say 300 lbs each. What's your estimate?
I will be scrapping these so I can find out what they weigh.
Old 04-08-2015, 08:29 PM   #107
I found a calculator online. 381 lbs each. Plus the frames.
Calculators - Steel Weight, Conversions, Carbon Equivalency & PCM | O'Neal Steel
Old 04-08-2015, 08:55 PM   #108
Chassis: I.H.
Scratch the surface to expose the metal. It could be the lost confederate gold shipment. 1143 lbs for 3 loads, at today's price ($1196.43/oz), that's about 14.6 troy oz per lb. SO you could have $19,965,784.55 US. If you have $20 million in gold, let me know, I can help you load it back in the bus to cash it in for a small %.
HolyBus is offline   Reply With Quote
Old 04-09-2015, 12:22 PM   #109
Chassis: TC2000 FE
Engine: 190hp 5.9 Cummins
Dear lord, as if buses are not heavy enough.
Nat
Old 04-09-2015, 12:44 PM   #110
Amen Nat.
I just took a spirited ride on the hwy and I can't tell any diff in ride but maybe a wee bit more poop. I took the fist wt. out quite a while ago so I really only lost about 800 lbs this time but the rear does sit a bit higher..1in maybe.. More than 1/2 the wt. of my trailer !!
One wt. left but that is very near the axle and requires lots of stuff to be removed...lots .. So it stays.
Old 04-13-2015, 12:50 PM   #111
Ok, took the ballast wts. to recycle and they were just a bit over 300lbs each. So I've lost a total of 900lbs.
The bus total wt. is 18,500 right now. Didn't get axle weights.
Without the RV mods the bus weighs close to 17,000.
Just topped off the tank and I'm still at 12.5 mpg avg for 4 fill ups.
The GVW is 25K.
Old 04-17-2015, 09:10 AM   #112
https://www.facebook.com/MuscleHorse...27150/?fref=nf
Old 04-17-2015, 09:12 AM   #113
you've made a few changes
Old 04-17-2015, 09:14 AM   #114
No caption needed
Old 04-17-2015, 10:21 AM   #115
India????
Old 04-17-2015, 10:22 AM   #116
I have to wonder what removing that much weight down low did to the center of gravity (?) Gotta' be a lot higher now. Maybe not as bad as putting a couple of SUV's on the roof, but...
Old 04-17-2015, 10:37 AM   #117
Doesn't feel any different driving. It did raise the rear about an inch. Do have several hundred pounds of batteries, water, gen, etc back there.
Old 04-17-2015, 11:12 AM   #118
I've been letting my S.O. practice in local parking lots, she's getting very good at driving the bus!!
Old 04-19-2015, 11:12 AM   #119
Originally Posted by dond View Post
Thanks everyone for the kind words. Today I installed a wireless rear view camera..... awesome! Wired it on a switch and run it when needed not just while backing.
Wireless 5" Car Rear View Monitor Backup Camera Antenna for Truck Trailer | eBay
Piece of crap. Failed after a few hours. They did replace the monitor and that lasted a few minutes.
Old 04-19-2015, 06:34 PM   #120
New curtains
I drank the Kool-Aid opus Skoolie Conversion Projects 176 06-03-2016 09:12 AM
Plan in works to fix 'Electric Kool-Aid Acid' bus lornaschinske School Bus News 0 03-16-2013 11:25 AM
15 kool buses for auction citrus co Florida racetearoffs2 Classifieds | Buy, Sell, Swap 2 02-12-2009 03:01 PM
Olde Skool update 7-7-07 KaptnKAOS Skoolie Conversion Projects 0 07-08-2007 12:42 AM
Old Skool's Got brake lights !!! KaptnKAOS Conversion General Discussions 16 06-26-2007 02:41 AM
