12-01-2014, 10:14 PM
Coachwork: Suoerior
Chassis: Chevrolet
Engine: 292
Rated Cap: 31
Helen the Superior Bus
Hi folks.New here.
Helen is my 1971 Chevrolet Superior Shorty school bus that I will be converting to a camper this summer.I bought this bus in April,sight unseen,and drove her back to Massachusetts from Cheyenne Wyoming.What a dream come true,she is the exact body year/chassis I wanted since I was a little kid! She is named Helen after my Grandma who told me never to give up.
I plan to do some heavy work come spring,and I have had mechanical issues dealt with.She does need a tranny seal replaced but that is it mechanically.
So far:
Removed seats
Replaced solid turn signals with arrow turn signals
Rebuilt Carb
New plugs
New fuel lines
New Distributor
Removed gas tank,drained,re-coated and reinstalled.
Bus drove great back from Wyoming with a fuel filter replacement in Columbus Ohio.Had issues in Rochester NY and had all the engine/carb work done,but bus was very tempermental from NY to Massachusetts,and it was finally figured out(2 garages later) that it had a a bad accelerator pump!
Bus has ran nearly perfect since.
She has 78,000 miles on her and has a newer 292 engine.
I started this thread as a documentary on what I plan to do.
Bus has jackknife door, and I really am looking to replace it with a "one in on out" style.Other than that,all other work will be on the inside as the outside is nearly perfect,save for some detailing like different colored rims,and some rubrrail detailing.
i do want to remove those swamp ACs and put in pop up vents
Bus has manual steering,drum brakes,and is a manual 4 speed.
12-02-2014, 09:28 AM
Re: Helen the Superior Bus
Welcome & Nice rig --- are you sure those are swamp coolers on the roof? They look just like standard Coleman a/c units.
12-02-2014, 09:50 AM
Coachwork: Suoerior
Chassis: Chevrolet
Engine: 292
Rated Cap: 31
Not really sure,I was told they are swamp coolers.I think they are very ugly,and not needed In this part of the country.They also add drag.
12-02-2014, 11:28 AM
Sweet! Gotta love those Superiors. I'd guess your '71 is one of the last bus body builds Superior did. My little bus is also a Superior---but one of the early ones. Still, I see similarities in the body design despite the age difference and I'll enjoy seeing pics of the interior construction of your bus. To what degree will you be modifying your rig? Take a look at Tango's door fix on his shorty. It's pretty cool. On my bus, I welded the two door panels together and hung them from a vertical pole so the whole door swings back along the side if the bus. Have fun, Jack
12-03-2014, 07:00 AM
Coachwork: ward
Chassis: international
Engine: dt360a
great looking bus! how bout a closeup pic of the mirrors please?
12-03-2014, 07:49 AM
Chassis: AARE
Engine: 3116 Cat 250hp
Good looking bus, should be relatively rust free coming from WY. I loved that first trip in mine, NM to IN.
Those look like standard Coleman low profile AC units to me. You must have some sort of shore power cord somewhere. Before
you take them off, it they blow cold you should be able to get a few bucks from Craigslist. You're right they are ugly and eat fuel
If you plan on any AC at all though they might be the best alternative in a shorty. I hardly think you would need two though. What
was your bus used for? Unless you have a generator they wouldn't have worked while driving. You're right, swamp coolers aren't much
good where there is humidity.
Are we the only ones left who have worked on carburetors?
Looking forward to pics of your conversion.
Dick
12-07-2014, 10:42 AM
Coachwork: Suoerior
Chassis: Chevrolet
Engine: 292
Rated Cap: 31
Bus is stored 65 miles from here,next time I am out there I will take pics,should be about weeks.Are you looking for a particular view like mounting brackets or whatever?
Seems that way in Massachusetts,most garages wont touch it! I am not mechanically gifted either
They have cords running long the roof and drain hoses off the back,I ill post s detail pic soon.The do run,but not cold,but I did nothing but turn them on to see if they work.My hope is the holes left will accommodate pop up vents.Long term(way long term) is under chassis ac.
12-07-2014, 10:48 AM
Coachwork: Suoerior
Chassis: Chevrolet
Engine: 292
Rated Cap: 31
Here is the Facebook page for Helen,lots of photos there also
If you stop by,please say Hi!
https://www.facebook.com/pages/Helen-th ... page_panel
12-07-2014, 10:59 AM
Coachwork: Suoerior
Chassis: Chevrolet
Engine: 292
Rated Cap: 31
Jack,here is what the cords look like
01-13-2015, 11:55 PM
Chassis: Chevy C40
Engine: 292
Rated Cap: 22
Not much going on lately,but got her out for a drive on a 50 degree day!
01-14-2015, 09:23 AM
Great looking rig and to me, just about the perfect size (unless you are a full-timing family of four with a dog & two cats).
And if that little gas burner ever gives up the ghost, a Cummins diesel would fit under that hood just about perfectly. Keep the pix coming.
06-11-2015, 10:51 AM
Coachwork: Suoerior
Chassis: Chevrolet
Engine: 292
Rated Cap: 31
Not much has been going on.I did start removal of the old 1970s rug yesterday as my brother worked on ignition timing.Timing is correct.
I was happy that the previous owner did now glue the rug to the floor.That old familiar blue speckled Superior floor is in almost like new condition.
The bus suffers from some hesitation when you release the clutch,like it is going to stall and it does sometimes.If you feather the throttle she will do stay running,but this(in Boston traffic) is dangerous and almost impossible.It also seems the the vacuum hose might be too close to the radiator hose,causing pinching. Bus backfires or coughs even thought the timing is correct.
Progress has been slow,but with some time off coming,looking forward to getting the rest of the rug removed and begin planning her new floor.
This bus was Government owned at one time by the department of defense in Wyoming,but was definitely a school bus first.
06-11-2015, 11:03 AM
Chassis: TC2000 FE
Engine: 190hp 5.9 Cummins
I completely agree.
Nat
06-11-2015, 12:28 PM
Sounds like it might be an ignition problem. Do yourself a favor and buy a Pertronix electronic module conversion kit. VERY simple to install!
06-11-2015, 01:42 PM
Chassis: AARE
Sounds like it might be lean. Does the accelerator pump work immediately with a healthy squirt? Could also be a bad vacuum advance diaphragm.
06-11-2015, 04:59 PM
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
I'd check the dist. bushing first off. Pop the cap + see if you can wiggle the dist. shaft. Also try turning the rotor forward + back-does the advance work? (can check by reving the engine with the timing light on.)
06-11-2015, 06:51 PM
If your bus has air injection into the exhaust manifolds, your problem is likely a bad mixture control valve (often called a gulp valve) and/or leaking (internally) check valves which attach to the manifold injection rack. Jack
06-11-2015, 06:54 PM
Chassis: Dodge S-600
Engine: 360 V8
Awesome little bus! Congratulations!
Any action for which there is no logical explanation will be deemed "company policy."- Akvol's Second Law of the Corporation
04-21-2023, 02:18 PM
#19
Hi Folks: It's been about 7 years since we have heard about Helen. I guess I can fill in some of the story. From what I understand, the OP lost his storage and had to sell the bus. He sold it to someone in NJ around 7 years ago. This bus recently came up for sale in NJ and I went down to look at it. The bus had the original seats reinstalled and it looks just like it did in the pictures. When I looked at it, it had a new dist, new plugs and wires, new fuel pump and a new alternator installed, the tires had tread, were holding air and did not appear to be dry rotted. The accelerator pump is still not working and it starts hard when cold, but starts good when warmed up. The seller, not the owner, said a gentleman brought the bus to him to get it running and to sell it. The body is in great shape except for some rot in one front fender, an easy fix though. I swallowed hard, real hard and pulled the trigger, hopping she could make the 6 hour trip back to Vermont. The lights did not work, but the seller helped us get them working. We pulled out from the sellers place with a ¼ tank of 7 year old gas that we added HEAT and octane post to, my son driving Helen and I following. We stopped at the first gas station to fill up with fresh gas. We could only add 5 gallons! Ho sh#t! Yup, the gauge does not work and we have a full tank of stinky old petro. Ok then, we limped along, and I mean limped. That first tank burned up quick, thank goodness, we were able to fill up on our second attempt with high test and things got somewhat better. Unfortunately all other tanks burned up quick also! Anyway we pulled into a Dollar General and I replaced the fuel filters with fresh ones and saw a marked improvement, but still not running great. We avoided all highways because the bus could not top 40 miles pr. Hour. The GPS rerouted us through Trenton NJ, thank goodness it was around midnight, but we spent most of the trip on secondary roads putting along between 25 and 40. A 6 hour trip turned into an 18 hour trip, but as fortune would have it Helen got us home with only minor issues, we lost one directional signal, one break light and one headlight, the seller offered two spare headlights, so we were able to replace the one that burned out. I might get a fine in the mail for running a red light trying to do my best to stay behind Helen and not get separated. I could not stay awake so my wife and I switched driving and sleeping. My son did not have any trouble, I kept asking him if he needed to rest because he kept swerving over the line. He said the way the gauge cluster is positioned he had to turn the wheel to read it. Anyway, we got home parked the bus ate breakfast and went to bed around 11 o clock Monday morning.
04-21-2023, 02:30 PM
#20
The next day my son and I went for a drive in Helen so I could get a feel for how she is running. It ran about the same as it did coming home from NJ. The bus will start if we pour gas in the carb due to the accelerator pump issue. Helen does not like hills, very slow and starts to get hot. I know it has carb issues, but I am suspecting it may have a hole in a piston. Maybe she got over revved coming from Wyoming to Mass? Not sure, but the bus is at my mechanic right now. I am going to have him evaluate the engine, I don't have the time to do it myself right now, so I asked him to do a compression test to see if the engine is even worth a new carb. If she is toast I have a 350 small block I can drop in for now while I decide on what I want to re-power it with.
