Old 01-12-2015, 04:20 AM   #1
Rated Cap: 75
Last Frontier Adventure Club Bus
In February of 2014 my wife and I bought our bus.
view the video:
http://youtu.be/fjO-AaeRxlg
The bus was pretty much a blank slate. The former owner had purchased it to move their belongings from Pennsylvania to Alaska with, so they had even removed all but three rows of the seats.
Unfortunately though, he'd removed them by pulling the bolts out on the wall side and then just snapping off the legs where they went in to their rusty brackets on the aisle side. He did this of course because to remove the bolt you need one person underneath the bus and one inside it. Combine that with the rust proofing coating on the bottom of the bus, and it just ends up being easier to just grind them off.
Next we built a bed platform at the very back of the bus
view the video:
http://youtu.be/88o3NvdhSJg
We had to kind of rush along for a while once the snow melted, to get the bus ready for a trip in May, by which we needed it to legally be an RV so we could insure it.
video: http://youtu.be/lBsKgzPYNBY
Our trip was actually to take a group of people (including Christopher McCandless' sister Carine McCandless) to hike out twenty miles to see another famous bus.
Bus 142 has seen a lot more wear than mine. Fun fact though, bus 142 was originally a school bus as well (judging by the yellow paint showing through the green) It then became a fairbanks city bus, and then in the 1960s Jess Mariner turned it into a bus house and towed it out into the wilderness.
I'll post some more photos up to flickr so I can share them here soon. We've actually made a lot of progress on our build: bedroom, bathroom, dining booth, couch, running water, etc... In the meantime here's the links to our other YouTube video updates:
JUNE 2014 UPDATE
http://youtu.be/z-u63SzGynU
JULY 2014 UPDATE
http://youtu.be/Y4y1zfBXEbA
AUGUST 2014 UPDATE
http://youtu.be/spy8gQqSWBA
SEPTEMBER 2014 UPDATE
http://youtu.be/TQl6--Mhy-E
OCTOBER 2014 UPDATE
http://youtu.be/8Ln4ydvshO4
DECEMBER 2014
http://youtu.be/ePvsJGDM-k8
LFadventureCLUB is offline   Reply With Quote
Old 01-12-2015, 08:47 AM   #2
Welcome
And great pictures
Old 01-12-2015, 09:03 AM   #3
Welcome, from the Sunshine State!
Seen you folks on youtube for a while now.
Old 01-12-2015, 09:42 AM   #4
Welcome, nice build!
dond is offline   Reply With Quote
Old 01-15-2015, 08:40 AM   #5
Wait a second....you hiked with Chris McCandless' sister to the place where his story ended?!? What was that like?
jadam318 is offline   Reply With Quote
Old 01-23-2015, 03:57 AM   #6
Rated Cap: 75
We did! That was a pretty intense experience. That was the third trip I made to bus 142 and it will probably be my last. Carine was, expectedly, pretty emotional when we got to the Teklanika River. Luckily for us it was very low both directions, thanks to some planning and keeping an eye on the weather. We did a video of that trip as well: http://youtu.be/jMN52iJV3qY
Old 01-23-2015, 04:00 AM   #7
Rated Cap: 75
I'm still working on getting together some photos of the build between when we just started and now, but for now here's a link to this month's update video: http://youtu.be/VjH3xFn_Y48
Getting the roof rack going was a challenge. I was worried that big sheet metal screws directly into the cross members, and silicone, wouldn't be enough to hold the floor flanges down tightly, but it is totally rock solid.
Old 01-23-2015, 05:36 AM   #8
Very cool, yall.
Old 01-23-2015, 07:42 AM   #9
I just watched that video. Thanks for the link, by the way. What a cool experience! I'm really glad you documented that.
Old 01-25-2015, 07:22 PM   #10
Rated Cap: 75
Build pictures so far:
A huge amount of time was spent removing the bolts that held the brackets for the seats to the floor. I started this project not knowing very much about a lot of things, and made the mistake of trying to grind them off instead of using a thinner disc and cutting them off.
The beginnings of the bed platform
Removing windows was kind of a scary prospect until I actually did it. Popping the four clips off surrounding each window and cutting the caulking was all that was needed.
We decided we didn't need the flashers. We had ideas about making sweet flashing party lights or something using different colors, but we decided for the sake of simplicity, and to reduce the risk of getting pulled over as often, we'd just remove them.
We covered the window holes with thing sheet steel, attaching the sheets with sheet metal screws and sealing with silicone.
The hole for the flappy stop sign and the flasher holes got the same treatment.
We began to frame out the bathroom. The wall that would house the plumbing for the shower and the one that would house electric outlet boxes are framed with 2x4s, and the rest are framed with 2x3s to shave weight.
The previous owner had covered the SCHOOL BUS decals with duct tape before driving the bus up to Alaska. Between the duct tape and the decals themselves, I had a hell of a time getting them off. In the end it took a blow torch, a scraper, a wire brush, and a lot of acetone to get them removed.
A surprising percentage of the lumber used in the bus was hauled this way.
Ryan's bunk over the foot of our bed.
Some creative framing to accommodate the wheel well.
We ended up using a lot of tongue and groove because it was the easiest way to follow the contours of the ceiling, it's light and it looks good.
Painting has begun! We went with flat black for the hood to keep glare down. We went with black for the front and back of the roof section so that eventually we could put some white vinyl decals up there.
So much time went into sanding every inch of the bus before painting.
Complete Paint Job
The sink installed in it's temporary location, so we could meet the requirements to get our RV title/registration from the state of Alaska.
The urine-separating/solid-composting toilet.
A robin I caught trying to make a nest inside of the bus. He was released after the photo.
The license plate we received after passing our RV conversion inspection
Finally, a way to lock the bus.
Installing the bluetooth stereo deck made working in the bus much more enjoyable.
Cubbies above the toilet
Bedside table/drawer in the bedroom
Installing some flooring in the bathroom and bedroom
privacy film over the bathroom window
Building hollow core doors for the bedroom and bathroom
Vent system for the composting toilet, built with a small PC case fan.
Our couch. It opens up for storage underneath, and the left arm opens up to house the inverter. Cup holders and small storage spaces are also built into the top of both arms.
I built a four-spot USB charger into the bedside table in the bedroom. No need for separate chargers for the cell phones. I can just plug straight into the table.
Jenna made curtains for the bedroom.
a 110v plug in the bedroom
Old 01-25-2015, 07:27 PM   #11
Rated Cap: 75
The bathroom coming together. Note the box sticking out of the wall in the upper right. That was a fan system to pull hot air from above a wood stove to a toe-kick register in the bedroom. Now that we've abandoned the idea of a wood stove in favor of a small propane furnace, we've removed that box and come up with another idea for that wall.
We got a bunch of very old skis for free from REI and decided to use them as trim, since our 'theme' for the bus was "mountaineering-hut on wheels."
Installing some seat-belts for the couch. Safety first.
Building the dinette benches and table. The table can be lowered to become a bed by placing the back cushions in the center.
Medicine cabinet in the bathroom.
A small closet built where the sink used to be.
Installing a roof rack.
I built this cubby/shelf to replace the flappy door to the 'emergency equipment access.'
The cabinets and counters I built last week.
So that about does it. I think I'm caught up now. I'll continue to post updates as the project progresses.
Old 01-26-2015, 03:17 AM   #12
You may find that using silicone was a bad idea for a sealer.
Using butyl rubber tape caulk would have worked better--it won't dry up nearly as fast and UV won't break it down.
cowlitzcoach is offline   Reply With Quote
Old 01-26-2015, 09:10 AM   #13
Year: 92
Coachwork: Ford
Chassis: B700
Hello,
We love the design of your skoolie. Especially your dinette area that turns into a bed. We would like to make the same thing. Do you have any plans that you would be willing to share? Happy adventures!
Thank you,
Jonas
powderzog is offline   Reply With Quote
Old 01-26-2015, 05:05 PM   #14
Hank's P-O-S's Avatar
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
How did you attach your roof rack? In your YouTube video you said you screwed in on? Like as in self taping metal screwed or did ya mean bolts? I've been thinking about something like that myself...
Hank's P-O-S is offline   Reply With Quote
Old 01-27-2015, 09:10 PM   #15
WOW! --- lookin' great guys! Keep up the good work and the pix.
Old 01-28-2015, 01:00 AM   #16
Rated Cap: 75
I don't yet, but I will draw up a floor plan.
Old 01-28-2015, 01:03 AM   #17
Rated Cap: 75
I screwed the floor flanges directly to the cross-members of the roof using #14 self tapping sheet metal screws. It's super solid as far as I can tell. Those #14s are really big screws.
Old 01-28-2015, 08:33 AM   #18
Chassis: I.H.
Wow, that is great progress! Looks real good. I was starting to think about the space I have and if it is enough but you made it look roomy. I can't wait to dive in and add an armoire I found at the Restore to fit over the wheel well.
HolyBus is offline   Reply With Quote
Old 01-28-2015, 09:18 AM   #19
Well to be fair they are showing what they've already done.
This bus is built. Although, buses are always "under construction".
Old 01-28-2015, 12:41 PM   #20
Chassis: TC2000 RE
Engine: 8.3l Cummins
I like your build! You might consider using sikaflex 295 (it's uv stable) instead of silicone caulk for sealing your gaps. I think you can get that stuff at many marine boating places.
Do you have any more details related to the composting toilet? I'm trying to decide between buying a one ready made (like the nature's head) or just building my own (like yours!)
aaronsb is offline   Reply With Quote
3800, alaska, family, green
