dopamine - did you do wheel upgrades to yours? are these turbos pretty decent in general? ie if I fuel-up a bit do I run the risk of damaging the stock turbo because of increased turbine speeds? i dont know much about diesel turbos.. my experience was more in gasoline stuff where people put insane amounts of boost into an engine.
I did upgrade the wheel from a 5 blade to a 9 blade compressor wheel. I was thinking to get my compressor housing machined to fit a LARGER compressor wheel but you dont want to go to big on the compressor wheel or it can put pressure on the bearings & seals on the bearing housing.
i didnt want to spend anymore money...
