10-02-2018, 06:06 PM
#21
Chassis: Ford E-350
Engine: Ford 351 Windsor
Rated Cap: 16
If I get some time I'll fetch all of the documents, then try writing a script to parse the various models/years and maybe even options. Seems like it might be pretty involved, depending on how the PDFs are generated.
11-04-2018, 08:44 PM
#22
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126
I have succeeded in creating a local mirror of the entire “seats” directory of the Thomas Built Portal, totalling 203,544 PDF files at ~31.5 GiB. The next step is to upload this mirror to a separate location, in order to reduce our community's bandwidth impact to the Thomas web site (admittedly probably not a lot but still not very considerate).
Many of the PDF files can be parsed. I will run some preliminary tests to determine how many of these files can be automatically categorized.
11-04-2018, 08:52 PM
#23
Coachwork: Thomas EF
Once you get them organized I can host a mirror on our site.
11-04-2018, 09:13 PM
#24
Engine: CAT 3126
Thank you. That would be really helpful.
I am not going to organize a damn thing, however. 😉 We need to keep these files exactly the way Thomas has them on their portal. Otherwise, we'll run into problems updating the mirror.
What I would like to do is create a separate “directory” listing of the files' contents, so people can easily find what they are looking for. I'll report back after finishing a preliminary survey. There is a lot to wade through.
12-07-2018, 09:15 PM
#25
Chassis: Thomas
Engine: 8.3l Cummins
I'm struggling to access the original link, has it been removed already or is that an issue on my end? I'm seeing the below message -
403 - Forbidden: Access is denied.
You do not have permission to view this directory or page using the credentials that you supplied.
I'm not known for having great credentials.
I don't suppose anyone pulled the 1998 Saf T Liner MVP - The body ID is 680499943676-140HS.
Twigg - I know you mentioned that you have the same bus as us, any chance you got the blueprints?
12-07-2018, 09:17 PM
#26
They probably saw the traffic and locked it down.
12-08-2018, 10:30 AM
#27
Chassis: Ford E-350
Rated Cap: 16
That's my assumption as well. Not too surprising, since it probably wasn't intended to be available publicly.
Marceps, could you make a torrent of your mirror?
03-30-2019, 08:58 AM
#28
Chassis: Saf T Liner MVP 11 window 32’
Engine: CAT 3126E
Howdy-I stumbled across this and was curious if you all had any luck storing all those files. I'd love to scour these plans for my bus! Sweet deck BTW.
thx
Eric
08-19-2019, 12:43 PM
#29
Engine: CAT 3126
Sorted and Aligned for Her Pleasure
My ISP (Comcast/Xfinity) does not take kindly to torrent traffic. If the home gateway they installed detects any torrent activity, it will silently boot those devices off the network. I have previously used a VPN to circumvent this but do not currently have a subscription. (AT&T is almost as bad, by the way... and those two are the only ISPs in town.)
Sasquatters, are you able to provide credentials for uploading to your site? I'm down for port 21.
Here is what I have found:
Folders up to and including 160000 are not readily machine-parsable. Luckily, this only represents 9,264 of 203,544 PDF files.
Unluckily, the bulk of drawings that feature pre-2001 buses is contained in those early files. For example, I had to find my 1999 Sat-T-Liner (body type 130-H-S) by browsing by hand.
For 2001 and beyond, you can download the whole damn list now. Here are some stats:
Code:
Body Style by Popularity
________________________
86842 TS
31985 MS
17172 YS
15083 PS
14677 S
3444 YN
2322 TN
2248 LS
1942 N
754 MN
603 PN
146 LM
36 HN
15 C
12 LA
1 PSS
Code:
Complete Body Type by Popularity
________________________________
24597 051 MS
18528 341 TS
14703 311 TS
13464 340 TS
10329 310 TS
9666 221 TS
8905 141 YS
7450 251 TS
7091 041 MS
5635 281 TS
4291 140 YS
3795 1418 S
3652 191 TS
3017 111 PS
2679 1408 S
2585 1318 S
2407 101 PS
2145 161 TS
1989 120 PS
1930 141 YN
1851 130 YS
1808 041 LS
1796 081 PS
1747 110 PS
1718 1218 S
1519 071 PS
1270 170 TS
1222 120 YS
982 341 TN
903 110 YS
834 0918 S
819 100 PS
739 1118 S
711 1308 S
705 061 PS
611 130 YN
592 091 PS
575 051 MN
561 1418 N
539 1208 S
531 1018 S
492 051 PS
440 040 LS
384 140 YN
320 1318 N
312 110 YN
259 1108 N
257 340 TN
244 1118 N
214 251 TN
214 311 TN
207 120 YN
204 0908 N
200 1008 S
196 1308 N
191 281 TN
187 0908 S
175 221 TN
174 040 MS
166 041 MN
153 0918 N
148 111 PN
146 041 LM
136 310 TN
123 050 MS
114 191 TN
106 120 PN
94 1108 S
78 071 PN
60 091 PN
50 081 PN
38 101 PN
37 1110 S
36 110 HN
35 061 PN
32 110 PN
31 051 PN
30 161 TN
25 100 PN
17 1010 S
15 1418 C
13 040 MN
12 041 LA
9 170 TN
6 0810 S
3 1405 N
3 0510 S
2 1415 N
1 091 PSS
1 1305 S
1 1405 S
This is the shape of Thomas things to come on skoolie.net as these buses increasingly trickle down into auctions over the coming years. I wonder if anyone here will end up with that one-of-a-kind 091PSS...
08-19-2019, 04:56 PM
#30
Code:
86842 TS
31985 MS
17172 YS
15083 PS
14677 S
3444 YN
2322 TN
2248 LS
1942 N
754 MN
603 PN
146 LM
36 HN
15 C
12 LA
1 PSS
Code:
24597 051 MS
18528 341 TS
14703 311 TS
13464 340 TS
10329 310 TS
9666 221 TS
8905 141 YS
7450 251 TS
7091 041 MS
5635 281 TS
4291 140 YS
3795 1418 S
3652 191 TS
3017 111 PS
2679 1408 S
2585 1318 S
2407 101 PS
2145 161 TS
1989 120 PS
1930 141 YN
1851 130 YS
1808 041 LS
1796 081 PS
1747 110 PS
1718 1218 S
1519 071 PS
1270 170 TS
1222 120 YS
982 341 TN
903 110 YS
834 0918 S
819 100 PS
739 1118 S
711 1308 S
705 061 PS
611 130 YN
592 091 PS
575 051 MN
561 1418 N
539 1208 S
531 1018 S
492 051 PS
440 040 LS
384 140 YN
320 1318 N
312 110 YN
259 1108 N
257 340 TN
244 1118 N
214 251 TN
214 311 TN
207 120 YN
204 0908 N
200 1008 S
196 1308 N
191 281 TN
187 0908 S
175 221 TN
174 040 MS
166 041 MN
153 0918 N
148 111 PN
146 041 LM
136 310 TN
123 050 MS
114 191 TN
106 120 PN
94 1108 S
78 071 PN
60 091 PN
50 081 PN
38 101 PN
37 1110 S
36 110 HN
35 061 PN
32 110 PN
31 051 PN
30 161 TN
25 100 PN
17 1010 S
15 1418 C
13 040 MN
12 041 LA
9 170 TN
6 0810 S
3 1405 N
3 0510 S
2 1415 N
1 091 PSS
1 1305 S
1 1405 S
How big is it? I would want them organized in a way that is easily accessible and easy to use for those looking for their model. We have a nice site and I wouldn't want to just throw up a zip and tell people to have fun.
08-21-2019, 10:08 PM
#31
Engine: CAT 3126
Here is the complete directory listing.
I agree you have a nice site. When you originally made the suggestion, I figured you were thinking of hosting these as a separate entity (for a number of reasons, actually).
08-21-2019, 11:36 PM
#32
Good stuff. I’m finding Thomas/Daimler to be very nice about sharing info.
10-02-2019, 05:51 AM
#33
Engine: 6.6 Duramax
Dude that is a nice site! Is that your company imbue? If so is that a theme you built or are you using the wordpress api?
10-02-2019, 11:18 AM
#34
For those of us less computer literate it will be quicker to take physical measurements of our buses...
Can anyone stick my nose on the 2002 Thomas Freightliner FS65 for 71 passengers?
10-02-2019, 08:58 PM
#35
Engine: 6.6 Duramax
I have all of the pdf's downloaded but I can't match anything against my body id, chassis id, vin or number of windows to any single pdf file name. Am I missing something?
10-03-2019, 02:05 AM
#36
Stick your nose here:
TBB 149399 11-Row 1110 Body Seat Plan.pdf
10-03-2019, 08:40 AM
#37
Originally Posted by Native
THANK YOU!!!
10-03-2019, 11:57 PM
#38
THANK YOU!!!
No problem, you just happen to have the same bus as I do!
11-12-2019, 09:35 AM
#39
I can’t seem to open the first link. Did anyone find a P3500 build link?
In a world where you can be anything, be kind.
11-22-2019, 12:09 AM
#40
Engine: CAT 3126
I have uploaded the seat plans.
How to Get a Seat Plan- Consult the list (previously linked). If you find your body style, contact me.
- If you don't find your body style, look here. Post details in this thread if you find it eventually, so the next person with your body style doesn't have to search randomly.
Forum posts are a horrible format for organizing such information, but it's all we have for now. If someone wants to start a publicly editable file (wiki article, Google Doc™ whatever...), please do.
