Old 01-07-2020, 07:04 AM   #321
bapos's Avatar
Chassis: International Amtran RE
Engine: DT466E/MD3060
I'll be the first to say I was skeptical as hell about getting this done. A member of my Facebook group found the allison master and sent me his way. The guy is seriously a good transmission guy and over all a great guy.
This is a worth while investment.
Bapos
fantastic that we have a reliable good way of getting these opened up.. this rocks and kudos to Bapos and his connection!!
Old 01-07-2020, 07:23 AM   #322
brokedown's Avatar
PM sent! Would love an alternative to sending the TCM off for a week.
Old 01-07-2020, 08:46 AM   #323
Me too!
I have been looking for a good buy on a spare TCM to send off for programming.. No need to now.
I am sold on having this gent reprogram mine. I do wonder how it will play if I have to go back to Alison for anything.
Old 01-07-2020, 09:12 AM   #324
TJones's Avatar
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
Me too!
It should be fine for service. You wouldn't want them to reprogram the oem cal file.
Ted
Old 01-07-2020, 09:14 AM   #325
bapos's Avatar
Will be a non issue. I asked him the very thing. They just wont be able to use the cal sticker on your tcm. Your in good shape.
Old 01-07-2020, 09:26 AM   #326
Truthseeker4449's Avatar
Chassis: MVP ER
Engine: CAT 3126
Is this the interface I would need?
https://www.cnautotool.com/goods-495...kaAsdcEALw_wcB
Truthseeker4449 is offline   Reply With Quote
Old 01-07-2020, 11:48 AM   #327
bapos's Avatar
Yes it will but......
Here's the problem with clone adapters. They do not have the ability to do check sum when sending program. What that means is the programming you send can get corrupted.and you may have to send it more than once. Not the end of the world but a possibility. It's why they are so cheap compared to the actual
Old 01-09-2020, 02:20 AM   #328
Chassis: MVP ER
Engine: CAT 3126
Oh is it a clone? I thought it was an older model.
Old 01-09-2020, 04:53 AM   #329
bapos's Avatar
The real thing is in the 700 range
Old 01-09-2020, 09:34 AM   #330
TJones's Avatar
Chassis: CS RE
Google search Nexiq and there are several articles on how to tell the genuine frome the clones. A used original Nexiq1 go for $300 to $400 on ebay. I found mine on facebook marketplace for $200.
Ted
Old 01-09-2020, 11:52 AM   #331
brokedown's Avatar
I have a clone on order from china via aliexpress for $125 shipped. We'll see if they meet their shipping estimate which was faster than I would expect.
Old 01-09-2020, 01:52 PM   #332
Chassis: GA39530
Engine: DT466E 215hp 620tq
Rated Cap: 40
6th gear option
So I dont know if this is going to work but Im giving it a try.
So I have an MD3060 with a DT466e and only 5 gears. I just purchased an Allison TCU from a International DT466e class 6 truck with 6 gears. The TCU is the newer 500k computer where mine is the older 250k computer.
The new computer is the same engine rpm range and same throttle detect but with 6 gears. So im hoping to be able to plug it right in and have the 6 gears.
The best part is it was only 110.00.
Ill report back once I verify that is works.
But it might be another option, just buy a TCU with the 6th already enabled.
FamilyCircus is offline   Reply With Quote
Old 01-09-2020, 02:00 PM   #333
it should work as long as both are set to the same throttle type and both are 3rd GEN.. meaning one isnt the 4th gen with the single connector....
Old 01-09-2020, 03:34 PM   #334
Chassis: GA39530
Rated Cap: 40
5sp to 6sp
So my old TCU has a CIN of 0B007RK0194 and the tag reads
"PRI Mode: 1-5S1 SEC Mode: 1-5S3" with a throttle detect of "AUTODETECT"
The new TCU has CIN of 0D008JD002L and reads "PRI Mode: 1-6S1 SEC Mode: 1-6S3" with throttle detect of "AUTODETECT"
I talked to my local Allison service manager and was told that the two modes on the tag with the "1-6S1" indicates its a 6 speed program.
Worse case its the newer 500k computer which I can have reprogrammed for the 6th gear, but im hopeful it will plug and play.
The only difference is the RPM range, Mine is 2400 rpm and the new TCU is 2500 rpm, shouldn't make that big of a difference since Im going to the higher tune of 230hp 660tq.
And they are both for DT466e engines.
Just some info for the community to use.
Old 01-09-2020, 03:40 PM   #335
the 2500 RPM means if you have your foot to the floor it wont want to shift till your reach 2500.. most 466s go up to 2600 max so it should be no big deal.. throttle type of autodetect on both is perfect..
Old 01-09-2020, 04:01 PM   #336
Chassis: GA39530
Rated Cap: 40
J1708 Servicemaxx
I've got a copy of Servicemaxx J1708 and can set the redline to 2500 although it doesn't make power up that high but to pull a gear it might work out better that way. Its currently at 2400 but I just changed it to 2450 just to see what would happen.
Old 01-10-2020, 01:15 AM   #337
Chassis: MVP ER
Engine: CAT 3126
This is what my Allison dealer recommended. I'm curious where you got that one.
I am currently talking with Bapos' 'Allison Master.'
Old 01-10-2020, 08:23 AM   #338
Chassis: GA39530
Rated Cap: 40
Fleebay, check for "Allison ECM" or any number of variations of computer, TCU, TCM, ECU Computer, Module.
I notice there were lots posted but few had any engine related info, but you can always ask the seller.
Old 01-10-2020, 09:19 AM   #339
bapos's Avatar
Why guess on this when you can get it done right? Bricking a trans like that is an expensive experiment
Old 01-10-2020, 10:24 AM   #340
WIbluebird's Avatar
Engine: 8.3 Cummins ISC
Rated Cap: 75
What's the best way to tell if my MD3060 is unlocked? I have 4.78 gearing. I forget what RPM's I was hitting, I want to say around 2100ish at 70 mph.
Mine's a Bluebird so doing the OEM approval letter for the 6th unlock (assuming I have it) is a no-go.
