RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-25-2020, 07:28 PM   #1
Joe45's Avatar
Bullbar?
So I'd like to make a custom bullbar for my bus.
Anyone done this?
Any ideas on how to make it to still allow the hood to tilt forward?
I am thinking of basically heavy duty hinges, maybe from 1/4" steel plates and grade 5 bolts, and pins to keep it in place. When I need to access the hood, I pull out the pins and fold the bumper forward.
Any ideas?
Joe45 is offline   Reply With Quote
Old 11-25-2020, 07:31 PM   #2
Chassis: IH
Yeah, get one to fit an IH 4700 (which is essentially the same chassis as the 3800), all the engineering is already done for you. They do pivot on one lower bolt to allow hood access, having a upper pin (or latch, in some cases) to keep them upright.
Old 11-25-2020, 08:09 PM   #3
Joe45's Avatar
Great to know! I will look that up!
Thank you!
Old 11-25-2020, 09:55 PM   #4
Joe45's Avatar
So far what I see is going for Just under $4,000 and up. If that's the case, I'll make my own!
Old 11-26-2020, 12:21 AM   #5
bus-bro's Avatar
Engine: 3208 na boat anchor
Wow, those things are expensive.
Be a chore to figure out and cut the angles. Then you got to pipe weld it together. Not too bad from someone who knows what they are doing. Me, I would make a mess with my cheapo flux-core wire feed. It be large, well fed house cat, guard. Maybe.
Old 11-26-2020, 09:03 AM   #6
Chassis: IH
A quick google search found some in the $1000-1,200 range. Not as elaborate, but still effective in protecting a $2500 hood, $1000 radiator and $1500 Charge Air Cooler.
Old 11-26-2020, 12:06 PM   #7
flattracker's Avatar
Engine: Cummins 350 big cam
Rated Cap: 86 passengers?
Look at a M998 Utility Truck (HMMWV) they have a "Brush Gard". Bambi ran out in front of mine and the HMMWV won without a scratch
flattracker is offline   Reply With Quote
