Old 10-18-2021, 04:02 PM   #1
A_Bus_Called_Quest's Avatar
Engine: DT466 / MD3060
Custom Cushions - LIFE SAVING Calculator and Tutorial
Skoolie Fam!
Just wanted to drop some info on this amazing cushion foam and fabric calculator, with a built in pattern / template and how-to video from Sail Rite!
https://www.fabric-calculator.com/cushions.aspx
No joke 30 minute cushions. I'm not an experienced sewer at all, but these cushions came out looking professional AF in my opinion
Here's the pattern I used. If you click "Main Menu" there are tons of calculators for cushions, pillows, curtains, etc. There are a handful of different cushion patterns, I used the 30 minute box corner cushion. Super easy, follow the directions and you'll be good as gold!
Fabric-calculator.com incase the link breaks
Highly recommended for anyone looking to make some custom cushions!!
Materials:
Ultra HD foam from Foam Factory (foambymail.com) - order as needed
Polyester FiberFill to cover the foam with - gives it that cushy feel.
Cotton Canvas from Joann - came in at $8.99/yard @ 45inches wide. I needed about 8yards for our 2 dinette seats and 4ft bench.
20211013_084321.jpg   20211013_084330.jpg   20211013_084308.jpg   20211012_161957.jpg
A_Bus_Called_Quest is offline   Reply With Quote
Old 10-18-2021, 04:25 PM   #2
SailRite.com is also an incredible resource supplies machines & tutorials all top notch
Old 10-18-2021, 06:31 PM   #3
Year: 2005
Chassis: FS65
Engine: Mercedes 6.4L
Rated Cap: just the 2 of us
your dinette looks great.
BarnYardCamp is offline   Reply With Quote
Old 10-18-2021, 06:43 PM   #4
Thank you! We will spend a lot of time there, we both will be working almost full-time on the road.
The best part, it transitions to a dog bed!
(Or people lounge, it is only about ft long so too short for a bed)Click image for larger version
ID:	61917Click image for larger version
ID:	61918Click image for larger version
Old 10-18-2021, 07:21 PM   #5
I thought I had the answer to my question of the dimensions of the dinette when you said it was only ? ft long. I plan on the same style dinette and need to know the width of the bases and the width of the gap?
Do your seat bases open for storage?
Old 10-18-2021, 07:41 PM   #6
Tejon7's Avatar
Chassis: Crown Supercoach
Engine: Detroit 6-71TA, 10 sp.
Rated Cap: 90 (40')
That looks really good! I'll be attempting cushions over the winter, so I bookmarked those links. Thanks for sharing!
Tejon7 is offline   Reply With Quote
Old 10-18-2021, 07:53 PM   #7
Oh my apologies! was on mobile - When flat, the "bed" is approx. 56" (+ a little wiggle room)
Each bench is 16" deep, 22" wide (you can Barely fit 2 people on each side if we need to party)
2x2 lip on the front for the table top to rest. The gap between is just a bit over 24". The cushions lining up so perfect was really a happy accident I didn't plan for - but each cushion back is 12" high, so there you have it. perfect fit.
I used these table brackets to mount to the wall, and this heavy duty hinge for the table leg. It is SUPER sturdy, if there was enough headroom I could probably stand on it.
I can lay on the "bed" when leaning up against one side, but not fully stretched out. It is perfect for lounging in the living room, one of us can take the bed side and one can take the 4ft couch on the other side, leaning up against the back of the driver's seat.
Also, yes! The bottom of the benches open, so do the backs for a little bit of vertical storage. Bottoms fold up, backs fold down - I'll get a pic up here sooner or later - we're starting to move in this week ;)
Old 10-18-2021, 08:02 PM   #8
I was going to ask about the hardware, but you beat me to it. I have about 68" to work with. so a couple more than you have. Unfortunately I have to build mine over a wheel well, but it'll work. I bought an RV dinette pole for mine. Definitely need to measure back and seat cushion for flat length to decide dimensions of the wood base.
Old 10-19-2021, 04:50 AM   #9
Your cushions (and the whole dinette) look fantastic.
Old 10-19-2021, 09:09 AM   #10
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
That's fantastic looking work, BG...and a great resource you shared. Just learning about the hot knife made the whole thing worthwhile. I've bookmarked that site - thanks!
Old 10-19-2021, 11:20 AM   #11
Chassis: Ford E450
Engine: V10 Gas
Originally Posted by Bear Gerschafer View Post
Skoolie Fam!
Materials:
Great site-thanks!
Old 10-19-2021, 01:31 PM   #12
Nicely done! Thanks for posting this.I’m just now getting over my fear of sewing and it’s nice to see people’s projects
Old 10-19-2021, 04:14 PM   #13
If you can saw a straight line, you can sew one! And I've seen those shower tile photos, I know you've got skills ;)
Old 10-20-2021, 04:18 AM   #14
Mercuric Mind's Avatar
Engine: Cummins 5.9 ISB 24v
Thanks for the info! It looks like it will be super helpful.
His only defense was to answer a question she didn't ask.
Mercuric Mind is offline   Reply With Quote
Old 10-23-2021, 03:43 PM   #15
Looks great! I’ve got a Sailrite machine and second the recommendation for their learning materials. Now off to check out the fabric calculator!
Polarweasel is offline   Reply With Quote
Old 10-23-2021, 06:47 PM   #16
The calculator was helpful but the pattern maker was priceless!! They weren't kidding when they call them 30 minute box cushions
Old 10-23-2021, 08:44 PM   #17
Year: 2009
Coachwork: Girardin
Engine: 6.6 turbo diesel
Rated Cap: ?
Your dinette looks great! Really nice job. And thanks so much for the shared info. I will definitely be referring to it when my cushion time comes down the road a bit.
Buster Junior is offline   Reply With Quote
Old 10-24-2021, 02:38 AM   #18
Chassis: ThomasBuilt 30'
Rated Cap: me + 1
looks good. What sewing machine did you use?
Old 10-25-2021, 10:26 PM   #19
My wife's lil Janome, not sure the model #. It is a pretty nice machine but definitely a "beginner level" / nothing super fancy or industrial.
Old 03-27-2022, 06:39 PM   #20
Thanks so much for the links! Also, super impressed with the dinette setup. 11/10 thanks very much for sharing!!
Mobbs is offline   Reply With Quote
cushion, custom cushions, fabric, foam
