Old 07-21-2019, 03:46 PM   #21
Coachwork: Blue-Bird
Chassis: TC RE 3408
I'm all done. All the galvanized is painted.
Toluene, as in trinitrotoluene, right? No thanks. I'll pass on that.
We once found 10 pounds of that in the woods, in a little old shed near a waterfall we hiked into, but my dad would not let us play with it.
gs1949 is offline   Reply With Quote
Old 07-21-2019, 03:48 PM   #22
Chassis: ThomasBuilt 30'
Rated Cap: me + 1
Originally Posted by Sleddgracer View Post
to pass industry standards, untreated galvanized steel surfaces need to be washed down with toluene before painting - you might prefer to stick to wiping with vinegar after reading about the safety precautions needed to be taken and the possible nasty effects on human health - when painting galvanized steel doors in a hospital renovation, we had to set up a low air pressure area to be sure not the faintest whiff of toluene could be detected outside of the work area
https://www.worldofchemicals.com/422...p-reactor.html
How do you set up a low pressure area?
Old 07-21-2019, 03:56 PM   #23
Sleddgracer's Avatar
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
seal off the area using plastic and duct tape, then use a fan to drive air through a large ventilation pipe to the outdoors - that creates a one way air floow - when you open the door to the work area, air rushes in rather than out - keeps dust from leaving the work area as well
Old 07-21-2019, 03:59 PM   #24
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
https://www.norseman.ca/en/portable-temporary-ducting
Old 07-21-2019, 04:30 PM   #25
Rated Cap: me + 1
So... seal an area off with plastic sheet, than set up a fan inside blowing into a duct going outside?
Old 07-21-2019, 04:42 PM   #26
HazMatt's Avatar
Chassis: IH 3800, 8 window
The opposite of working in a confined space, which you forcibly vent fresh air into the containment area via a 2' flexible hose & high velocity fan.
Old 07-21-2019, 06:08 PM   #27
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
that's the idea - simple when you see it in operation
