01-24-2020, 05:46 PM
#21
Originally Posted by TheHubbardBus
there are people here who have used it successfully.
My floor is either rusted metal where the galvanic coating is long gone (along with all the steel in some places) or else still has paint on it and the metal is untouched underneath. So once you ospho the floor, the rustoleum will either contact ordinary steel (with some iron phosphate dust on it) or the original paint (which rusto seems to adhere fine to). That's probably why so many people use this on the floor and it works for them.
Interestingly, this article says that galvanized steel will lose its zinc layer in about 10 years if kept in wet or soaked environments - which I guess is what my bus floor was for most of its life, thanks to the leaky windows.
01-24-2020, 06:13 PM
#22
Coachwork: IC / Amtran
Chassis: CE300
Engine: International T444e
Rated Cap: 23
When it comes to rust restoration, you are the King, musigenesis! (It's Elvis's old plane)
Go away. 'Baitin.
Our Build: Mr. Beefy
01-24-2020, 06:19 PM
#23
Aw man, don't give me any ideas. I'm already thinking of volunteering on New Jersey or Olympia.
01-24-2020, 08:06 PM
#24
Chassis: CE300
Rated Cap: 23
You'd be a valuable asset.
Seriously though, we so admire your attitude & the incredible amount of work you're putting in to this project. Haven't commented in your build thread, but it's been one of the most inspirational to read.
Go away. 'Baitin.
01-24-2020, 08:24 PM
#25
Well gosh, I'm glad you're enjoying it!
01-26-2020, 10:28 AM
#26
Chassis: CE
Sikaflex 221
I took my floor to the metal, ground off the rust, used Corroseal on it, then sealed the holes with Sikaflex 221, an automotive caulk. I've used the Sikaflex all over my bus, and I love it. It goes down easy, stays down, is flexible, and if I have to take it off again, it comes off reasonably well with a putty knife. Caveat: I've never used it over Rustoleum, so no guarantees there, but I wouldn't be concerned.
You can get it on Amazon. It's about $10-15, but a tube goes a long way. My biggest complaint is that you can't buy it in less than a 10 oz tube, so I have to save up all my caulking jobs to do at once so I'm not wasting a partial tube.
01-26-2020, 11:54 AM
#27
I just got done having breakfast with a friend who is a 30 year flooring installer. He’s done it all. I posed the question to him. He says glue-down vinyl plank is the way to go. He says that the glue down stuff is less susceptible to thermal expansion. I asked him about sheet material and he said that until it’s in place, the good stuff is too brittle for anyone without a lot of experience to install successfully. He says the stuff at Home Depot and the other retail outlets is not durable enough. He also said that the good vinyl plank isn’t available at the big box stores. I asked what brand. He doesn’t have current info since he’s been retired, but says he will ask another career guy what’s currently the good stuff.
I also asked him about installing before or after furniture. He said to do it after since there’s less chance of a loose nail of screw or dropped tool gouging it. He says that the stuff is easy enough to cut and notch to do it after.
When I get brand info I will update with what he has for that. I told him to make sure to tell his guy that it will be installed in a vehicle and subject to extreme temperature variation.
01-26-2020, 12:38 PM
#28
I think vinyl planks have to do with brand and quality
I went to an outdoor viewing platform in a park yesterday it was built with vinyl planks probably about 5-7 years ago. They are still solid and in great shape. I also know of another park where vinyl planks are years old and still holding up solid.
I have seen a couple of vinyl porches done on homes that completely went to hell in less then 2 years. The sun deteriorated the vinyl and the planks warped.
Seems like some of it might be the grade and mixture of the vinyl.
01-27-2020, 07:59 PM
#29
Engine: 7.3 Turbodiesel Caterpillar, 3126
Originally Posted by Ronnie
Silicone is hydroscopic, meaning it attracts and hold moisture. Use uranthene based sealants , or butyl rubber based sealants.
Do you not recommend using silicone anywhere on the bus? Isn't that what's made for sealing water out of windows? When WOULD be the time to use silicone?
-The dumbest guy in the room.
01-27-2020, 08:07 PM
#30
Originally Posted by neversayneverbus
And I haven't done mine yet, but I think deleting the booster pump only works for front engine buses. On the pusher buses, you may need it to get the coolant all the way to the front for the defrost.
Ours is an engine-in-front shorty.
Originally Posted by BaconFarms
3M - 08368 - Urethane Seam Sealer, White, 310mL Cartridge - 60455054639
BaconFarms
The interwebs say not to use this on bare metal. What did you use as a primer for this?
01-28-2020, 10:08 AM
#31
Chassis: CE300
Rated Cap: 23
https://multimedia.3m.com/mws/media/...8361-08364.pdf
Look for the 'TDS' or 'Technical Data Sheet' for anything you don't want to take the interwebz word on ;)
Go away. 'Baitin.
01-28-2020, 10:47 AM
#32
That weld-through property is most interesting. From the description, it seems you spread the stuff on the two surfaces you're mating, clamp them together and then spot-weld them. Presumably resulting in a watertight join.
It also says residual acid from etching primers will weaken the bond of the sealer. I wonder if ospho has the same negative effect.
01-28-2020, 10:58 AM
#33
Chassis: CE300
Rated Cap: 23
I'd think ospho would absolutely have the aforementioned negative impact if not thoroughly rinsed/neutralized before application.
Go away. 'Baitin.
05-15-2020, 09:41 AM
#34
Sealing holes in the floor
So after mush time spent with a torch cutting off hundreds of bolts that held the wheel chair tie down strips to the floor of our bus it's time to grind, wire brush, rust convert and paint. All pretty straight forward. The bolt holes only need to be covered and sealed. Has anyone tried the self sealing ice and water shield that roofers use? Thanks
05-17-2020, 12:17 PM
#35
Engine: DT466E (195hp, 520tq)
I guess that would work. We used the black windshield goop that comes in tubes from the auto parts stores.
Dave
05-17-2020, 01:01 PM
#36
Year: 86
Chassis: Ford B700
Engine: 8.2
that stuff is expensive for that purpose?
and i think it would trap water slung up from underneath and create an unnoticable problem.
some have used caulking and glued pennies down.
but if you have a torch why not just get some of the wire cloths hangers and fill the holes in?
