Old 02-06-2019, 06:30 AM   #101
I love those gauges that are programmable!. you can also measure your tank depth and bend the float to the proper arc for true empty to full if need be.. I like my float to bottom out where its still above the fuel pickup.. so I have some "fumes" to run on when Im reading E.
Old 02-06-2019, 03:46 PM   #102
ComfortEagle's Avatar
Coachwork: Gillig
Chassis: Phantom
Engine: CAT 3208
Rated Cap: 87, says Gillig...
These SpeedHut gauges were not free but they are beautiful; maybe someday I will get to see them all in action... For the record I misspoke about the original sending unit, not that it matters, but it was 0-90 ohms, not 0-30 ohms... I like your float idea, but I'll just set the programmable low warning light on my fuel gauge to come on.
ComfortEagle is offline   Reply With Quote
Old 04-06-2021, 10:43 AM   #103
Chassis: Saf-T-Liner WestCoast-ER
Engine: CAT 3116 TA 250
As the owner of a bus with a janky instrument cluster that's mostly hidden by the steering wheel, this thread is super-informative and inspiring.
The results you've achieved so far could be accurately described as being "bad as hell."
Thanks for posting this thread and especially for the detailed links to the exact products you're using. I was curious about switching to a push-to-start system, and didn't really know where to look.
mantis is offline   Reply With Quote
Old 09-14-2021, 08:20 PM   #104
DrDanger's Avatar
Year: 2005
Originally Posted by ComfortEagle View Post
I continue to slowly get the dashboard figured out. I have the design of the driver side console finalized and hope to start building this weekend. I finished assembling the switch panel and wired up the switch lighting. I really like the etched rocker switches. I was also able to mount the transmission gear indicator LED on the panel as well.
Not a great pic but shows the lit up switches...
What material are those switch pods mounted to? I am redesigning my dash and haven't found an adequate backer for the switches I am going to keep.
Just some pilgrims, building a skookie
https://www.instagram.com/pilgrim_days/
DrDanger is offline   Reply With Quote
