10-11-2019, 01:31 PM
How can we decode VIN's
How do we decode VIN numbers?
Thanks
10-11-2019, 02:02 PM
Best and easiest is to call the manufatcurer and give them the VIN, they will be able to tell you everything about the build.
10-11-2019, 02:52 PM
Engine: Cummins 8.3 ISC 300
Rated Cap: 36,200lbs
Thanks
https://www.gates.com/us/en/ymm/search/landing/vin
10-11-2019, 02:53 PM
Worst case your friendly local dealer
10-11-2019, 03:22 PM
Engine: T444E 7.3L
10-11-2019, 05:51 PM
Bluebird has a nice web portal where you can look up their buses by vin, chassis id, service number, or serial number. Thomas doesn't have anything like that.
10-11-2019, 07:01 PM
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
Originally Posted by Johnny Mullet
I got, 'sorry, we can't decode that number'
10-11-2019, 08:14 PM
Rated Cap: 34
I got the same thing on my International.
10-11-2019, 09:31 PM
I use free truck vin decoders I find via google. Works well enough for me to get the basics on buses I bid on with little info in the listings.
10-12-2019, 12:26 AM
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
10-12-2019, 12:36 AM
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
won't/cant decode my 75 chevy bus - it only has 13 characters in the VIN, not the 17 characters that became universal in the 80's
10-12-2019, 06:35 AM
http://www.73-87chevytrucks.com/tech.../1975truck.pdf
10-12-2019, 12:36 PM
As the owner of a bus now, don't you need to change your "still looking for my bus" tag in your profile? Or have you misplaced it already?
10-12-2019, 03:19 PM
I Googled "truck VIN decoder" and tried them out.
What I got was the same as the "car" VIN decoders. I plugged in the VIN from my Bluebird and received the same results. Either a scam trying to get you to pay for the results or a genuine decoder that tells me make, model and engine. No other info like transmission or rear gears.
I have had good success calling the manufacturer with VIN or body service number. Very detailed information is readily available from your local Bluebird or International dealer. I have not tried Thomas.
10-12-2019, 10:33 PM
CMV ID: A Web-based VIN Decoder for Trucks, Buses, and Trailers
VIN Decoder
I think I've used these two before but I only look for the most basic of info.
10-12-2019, 11:32 PM
Both yielded make model and engine. No other relevant details.
Try my VIN out and see what you get?
1BABKBXA22F204158
10-16-2019, 05:47 PM
Year: 2006
Engine: MBE 906
What are trying to decode? Are you looking for build sheet or just to know chassis data?
You can use the body number for a Bluebird using the vantage https://vantage.blue-bird.com/Portal/Vantage-Home.aspx
Thomas buses uses the last 7 digits of the VIN, but you have to have a login. Freightliner uses the last 6 digits of the VIN, you must also have an account.
I have access to the Thomas side and would be happy to help if you have a Thomas
10-16-2019, 06:16 PM
If you have an international, let me know what your vin is and what specific info you want to know.
10-16-2019, 07:36 PM
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
tried to do that the other day - answered all/most of the questions but nothing changed
10-16-2019, 07:39 PM
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
