Old 06-26-2015, 09:32 AM   #1
vonslatt's Avatar
Engine: CAT 3208 NA
Modifying Windows to open from the bottom
I finally put together a tutorial on how to modify the windows in my Thomas to open from the bottom like regular double hung windows. Video and pics are here:
Bus Windows that Open From the Bottom
My 1989 Thomas Saf-T-Liner
vonslatt is offline   Reply With Quote
Old 06-26-2015, 10:35 AM   #2
Chassis: B3800 Short bus
Great tutorial! Thanks for the contribution
Old 06-26-2015, 07:27 PM   #3
very nice thank you for sharing.
Old 06-27-2015, 09:36 AM   #4
Count me in on doing this conversion!
c_hasbeen is offline   Reply With Quote
Old 06-27-2015, 10:43 AM   #5
Great Mod!!!
Seems like doing this on a homemade carpeted easel (scrap lumber) leaned up against a wall would make it easier than a workbench table top.... you'd be laying the window assembly on a little bit of a tilted surface. Swivel rolling chair, work on right side, then left side, and lay each rail beside you..., modify, then reassemble
I mean, once you get one done.... you got 29 more to go! (23 in vonslatt's case)
might as well get comfortable, you're gonna be there a while
or a folding ladder with a ledger board attached
I can't stand over a workbench that long
Old 06-27-2015, 11:26 AM   #6
Engine: 190hp 5.9 Cummins
Do they leak water after?
Old 06-27-2015, 03:23 PM   #7
Would this procedure be the same for a Bluebird? I'd love to have a few open from the bottom.
The-Breeze is offline   Reply With Quote
Old 06-27-2015, 07:29 PM   #8
I was wondering the same thing,
hope so
Old 06-27-2015, 07:35 PM   #9
Originally Posted by milkmania View Post
Great Mod!!!
but you still have to wear the hat
Old 06-27-2015, 09:57 PM   #10
I got this!!!
Old 06-27-2015, 10:04 PM   #11
It appears to me that by taking the window completely apart and reversing the slide up part to slide inside of the stationary top piece the weather stripping is still in place to control draft and I guess gravity does the water.
Old 06-28-2015, 06:43 AM   #12
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
I got this!!!
No no, you need a lightweight fedora
Captain Obvious on deviantArt
Old 06-28-2015, 07:50 AM   #13
dang..... you make it tough
had to dig back about 47 years... it's not "lightweight", but it's the best I could do
Old 06-28-2015, 08:10 AM   #14
^ Lookin quite dapper!
Old 10-27-2021, 11:42 AM   #15
vonslatt's Avatar
Engine: CAT 3208 NA
Just to follow up - they do not leak and have worked flawlessly these last 6 years.
how to, saf-t-liner, thomas, tutorial, windows
