06-26-2015, 09:32 AM
Engine: CAT 3208 NA
Modifying Windows to open from the bottom
I finally put together a tutorial on how to modify the windows in my Thomas to open from the bottom like regular double hung windows. Video and pics are here:
Bus Windows that Open From the Bottom
06-26-2015, 10:35 AM
Chassis: B3800 Short bus
Great tutorial! Thanks for the contribution
06-26-2015, 07:27 PM
very nice thank you for sharing.
06-27-2015, 09:36 AM
Count me in on doing this conversion!
06-27-2015, 10:43 AM
Great Mod!!!
Seems like doing this on a homemade carpeted easel (scrap lumber) leaned up against a wall would make it easier than a workbench table top.... you'd be laying the window assembly on a little bit of a tilted surface. Swivel rolling chair, work on right side, then left side, and lay each rail beside you..., modify, then reassemble
I mean, once you get one done.... you got 29 more to go! (23 in vonslatt's case)
might as well get comfortable, you're gonna be there a while
or a folding ladder with a ledger board attached
I can't stand over a workbench that long
06-27-2015, 11:26 AM
Engine: 190hp 5.9 Cummins
Do they leak water after?
06-27-2015, 03:23 PM
Would this procedure be the same for a Bluebird? I'd love to have a few open from the bottom.
06-27-2015, 07:29 PM
I was wondering the same thing,
hope so
06-27-2015, 07:35 PM
Originally Posted by milkmania
Great Mod!!!
but you still have to wear the hat
06-27-2015, 09:57 PM
I got this!!!
06-27-2015, 10:04 PM
It appears to me that by taking the window completely apart and reversing the slide up part to slide inside of the stationary top piece the weather stripping is still in place to control draft and I guess gravity does the water.
06-28-2015, 06:43 AM
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
No no, you need a lightweight fedora
06-28-2015, 07:50 AM
dang..... you make it tough
had to dig back about 47 years... it's not "lightweight", but it's the best I could do
06-28-2015, 08:10 AM
^ Lookin quite dapper!
10-27-2021, 11:42 AM
Engine: CAT 3208 NA
Just to follow up - they do not leak and have worked flawlessly these last 6 years.
