Is your hot water heater vented or ventless?
If vented, I'd make sure the vent is well away from anything combustible. You can always run the plumbing a little farther to the sink or bath/shower.
If it's ventless, then there should not be a concern, as the hot water heater is contained inside the bus, and the diesel fill spout is outside.
That said, if it's a ventless, make sure the hot water heater has a way to let the heat vent into the cabin. I mistakenly put mine under the kitchen sink not realizing how hot the radiated heat is.
Steve
