Safety is great but in practice propane is pretty hard to ignite unintentionally and liquid pooling in the lines takes some pretty severe conditions.
I'm trying to plan a conversion and one of the things that will determine the floorplan is the plumbing layout. Propane lines should be as simple as possible with few joints and with some rubber so road vibration will only shake the hard lines, not bend it.
Black iron pipe is used because galvenizing can flake off, clogging burners and regulators.
I would use as little as possible unregulated gas line and run a pretty low pressure on the regulated side, that will reduce the amount of propane loss if you do get a leak. Reduce it enough and the propane to air concentration will get so low that it won't ignite even with an ignition source (unless the ignition source is right on the leak).
I'll probably run a direct line from my propane tank/regulator to my refrigerator so it can run on the road but if my stove or water heater lines have to run under a frame rail, I'll put in a shut off valve for traveling.
I wouldn't necessarily rule out plumbing with an armored flexible hose but I like a nice pipe thread and Teflon tape joint better than a flare fitting. Some pipe dopes leak a lot so I don't think of it as a Teflon alternative.
If you can plumb fresh water piping, you can plumb propane pipe, you just have to be smart about the layout to avoid leaks due to rubbing, bending or vibration and add shut off valves where appropriate.
Back to the topic of liquid propane in the vapor lines, that only happens when there is a low spot in the line and it is cold enough that you are in the liquid portion of the propane phase diagram. The higher your line pressure, the higher the boiling point is so a lower line pressure means propane won't condense unless it is really really cold. Also, when it's that cold, propane in the tank won't vaporize so there will be no pressure pushing liquid or vapor propane in to the lines.
The usual outcome if you do get liquid propane condensation in the lines is your line begins to act like a small unregulated propane tank and once you begin to use it the liquid will vaporize until the liquid has been vaporized and burned off.
