Old 05-17-2023, 06:07 AM   #1
The lazy farmer's Avatar
rear hitch installation.
Got rained out putting crops in the ground so I had my son and nephew help install my hitch.
It's a weld on modified to bolt on. Rather than weld on we marked the factory holes in the bumper and drilled the brackets to fit.
Removed the tow hook assembly. That had 1/2 bolts. Had to use a bridge reamer to enlarge the factory holes in the frame from up to 5/8. The bumper bracket holes are slotted so had to trim a little off with the plasma cutter.
This is a 20k curt hitch with the 2 1/12 inch receiver. I will never pull that much but I wanted it to be plenty big.
Proud dad moment. My son wearing protective gear without being told to. Should have had sleeves and better shoes that didn't collect sparks but I will take what I can get from this one.
347250850_161713246628760_2685323120431793268_n.jpg   347263662_257782493487677_304236280247308465_n.jpg   347086192_617924127063547_7846840096591609486_n.jpg   347230462_260948343062813_6714852436356113910_n.jpg   347244040_229935916334040_299712594231722401_n.jpg
Father, husband, Farmer, trucker, Scoutmaster for our local Boy Scout troop.
The lazy farmer is offline   Reply With Quote
Old 05-17-2023, 05:45 PM   #2
Ronnie's Avatar
Engine: 345 international V-8
Love the bridge reamers, so much nicer then trying to drill a hole bigger with a regular drill bit. Nice job.
Old 05-18-2023, 06:50 AM   #3
Crawlerhauler's Avatar
Engine: 5.9 12 valve Cummins
I love it, I am doing the same thing. I was trying to drill out the holes in the frame. But my bit took a crap. So I have to stop by the store and get a new one.
Crawlerhauler is offline   Reply With Quote
Old 05-18-2023, 05:44 PM   #4
Marceps's Avatar
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126
I envy your spacious workshop—with with a helper, to boot. You are going to have a great conversion in no time.
Thank you for sharing.
Marceps is offline   Reply With Quote
Old 05-18-2023, 10:41 PM   #5
fo4imtippin's Avatar
Chassis: TC2000 28ft
i used the same hitch. Real beefy guy! I liked how you could squeeze it up to the frame rail to get it high of the ground for clearance.
Old 05-19-2023, 06:32 AM   #6
Do yourself a favor and get a bridge reamer. They are a little pricey but well worth it. You will need to spray it with some cutting fluid as go to keep it cool. 8 holes took me less than 5 minutes to enlarge.
Old 05-19-2023, 08:09 AM   #7
Chassis: International 1753
Engine: 6.9 International
Looks good! Do you plan on pulling a trailer for the scouts?
Old 05-25-2023, 06:31 AM   #8
Yes. We are going to the black hills of South Dakota in a couple weeks.
Old 05-25-2023, 12:28 PM   #9
Chassis: ThomasBuilt 30'
Rated Cap: me + 1
Nice shop.
Old 05-27-2023, 12:11 AM   #10
Lol I got mad after breaking half the big bits I had. Then I seen reply a hair to late. I pulled out the plasma cutter. Can’t break bits if it’s liquid took a washer clamped it in place. Wish I’d done that in the beginning.
