Old 07-06-2024, 05:23 PM   #1
receiver hitch install on 2001 Amtran (International) RE bus
I haven't found much info for a receiver hitch which would fit my bus, so I figured I'd share what I did.
The outside of the frame rails are 34" wide. This is narrower than most pickup trucks. Adjustable hitches are out of the question for me because i wanted a class 5 hitch. I found that cab and chassis trucks have a 34" wide frame, so off to FB Marketplace I went. After many months of searching (because I'm a cheapskate), and measuring I found a used Curt 15845 receiver hitch for $50 with no hardware. This is a commercial duty hitch
rated to 20K lbs (2700 lbs tongue weight) with or without a WD hitch! It's intended for 1999 and up F-350, F-450, F-550 and F650. The receiver is 2.5".
To get this hitch in place, I removed the bumper and then had to remove a bit of steel from the side pieces which block the air from coming up from the bottom. I intend to use a rubber to cover those areas in the future. Here's a pic:
I ordered the hardware kit from eTrailer ($60 shipped for eight grade 8 carriage bolts, serrated flange nuts and four square hole spacers!!). Do not use hardware store grade 8 bolts. I twisted several before deciding that hardware store grade 8 bolts are not really grade 8. Grainger, Fastenal, Cat were options, but it is impossible to find grade 8 9/16-12 carriage bolts. I had to make two plates with two 1/2 square holes each to hold the Curt bolts from spinning.
ID:	78149 Click image for larger version
The 9/16" holes into the bottom of the frame weren't too bad to drill (used a floor jack under the electric drill as a sort of drill press, but the two 1/2" horizontal holes on either side were a pain in the you know what! I had to use a stubby 1/2" drill bit on an angle adapter, but still couldn't get to two of them. Ended up using a stubby 5/16" drill bit and drilled the hole crooked, then used a carbide burr bit in a Dremel tool to square up the hole and enlarge it to 1/2". I used a shop vac and propped the hose near where I was grinding to keep the chips off my arms and clothing. Those suckers are like needles!
I had to notch the bottom of the bumper a bit.
I intend to use a brake controller in the driver's area, a tail light converter mounted in the electric cabinet outside of the driver and a 7-way cable from there all way to the rear bumper for the trailer lights. I'll write that install up in a week or so.
20240630_133245_resized.jpg   20240703_165244_resized.jpg   20240630_132801_resized.jpg
cruizinbiker is offline   Reply With Quote
Old 07-06-2024, 06:36 PM   #2
nikitis's Avatar
Rated Cap: 29
If you are hauling 10k, you'll want a minimum of 3 large bolts on each rail, and you seem to have them. I wouldn't test the 20k
Old 07-07-2024, 09:17 AM   #3
The trailer is rated for 10k, so I won't be going over that.
Old 07-07-2024, 07:44 PM   #4
nikitis's Avatar
Rated Cap: 29
Should be good to go then!
