01-18-2018, 05:23 PM
Chassis: Ford B600
Rated Cap: 20 person
Replace Emergency Exit with skylight
So my wife, who is in charge of the skoolie layout, just told me that one of the emergency exits will be a skylight. I am good with that because I don't have to patch it over now.
Here's the rub, I have no idea how to do this. Does anyone know or have seen anything like this being done?
"Living Our Own Story"
The Bowser Journal
Watch our adventures by subscribing...
Youtube - bit.ly/TheBowserJournal
01-18-2018, 06:01 PM
Go to Sojourner's thread and start at post 571.
01-18-2018, 06:27 PM
Engine: Dt466e
Rated Cap: 71
Perfect time to ask, because he just completed 4 great looking ones!
01-18-2018, 07:12 PM
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Not to argue with SWMBO, but a skylight also lets in heat during the summer months. At least the E-hatches are somewhat translucent rather than transparent.
01-18-2018, 08:26 PM
Chassis: Ford B600
And in the winter when you need it! I can always put up a curtain to knock down the sun in the summer!
The Bowser Journal
01-18-2018, 08:29 PM
I like RV roof vents. VERY functional and they draw very little current so they're great for cooling down without a lot of battery drain.
01-18-2018, 08:33 PM
Perhaps they use curtains over the skylights during the summer. I'd put insulation panels in the skylights for thermal purposes, which of course cancels the original purpose of the skylights.
I've found I don't like the strong sunbeams coming in through the ceiling during the summer, and I'm only using the hatch. The sunbeams are like a spotlight aimed in through the ceiling making it difficult to see anything that isn't hit by the beam of light.
Robin
Nobody's Business
01-18-2018, 09:12 PM
I'm okay with the rigid foam plugs for the skylights, that way you can have the light come when you want and closed when you're trying got cool. My only experience living in a tin can happened in 1975 when I first moved back to southern Calif and stayed with my brother. he had no bed space in his crammed house so I had to sleep in his converted van. Let me tell you, once that sun came up you didn't need an alarm clock, you started baking before 8 am.
01-18-2018, 09:56 PM
If you strip down the interior of a bus, you'll definitely feel the heat if you're in the sun. I'm in a colder climate and this bus was unbearably hot with just the outer skin for sun protection in the early summer before it got insulated. Having my head near the ceiling was like standing under a broiler.
Robin
Nobody's Business
01-19-2018, 03:25 PM
Engine: Dt466e
Rated Cap: 71
I hadn't even considered that. That's gonna make me rethink the idea.
01-19-2018, 03:59 PM
Chassis: Ford B600
We will have two fantastic fans along with the skylight
The Bowser Journal
01-31-2018, 09:45 AM
I skinned over my exit hatches with 20ga galvanized steel, as they were leaking quite badly. Ended up putting a Maxxair fan in the forward hatch. Now I'm thinking I want a skylight where the rear hatch was.
What do you think of this?
https://www.ebay.com/itm/PREMIUM-Hea....c100677.m4598
I think if I paint the bezel white it will hide the butyl caulk and screws along the seam. Other than hiding the seam I think this should work great. Thoughts?
01-31-2018, 02:22 PM
I love this idea, I am not sure about the mechanics of it but I do indeed like the idea! Good luck doll!
02-06-2018, 03:28 PM
I like what Sojourner has done for skylights.
I want to replace my escape hatch with a skylight as well. Major caveat: Since I do plan to use mine for people-hauling, I think it would be a good idea to keep it usable as an escape route. So ... any suggestions for a skylight that still meets the requirements for getting-out-in-a-hurry?
An emergency roof escape is one of those things like a parachute or fire extinguisher. It's one of those things you hope you never need, but if you do, nothing else will really do the job and you need it *RIGHT NOW*.
02-06-2018, 04:27 PM
I'm sure glad I bought this parachute. I actually did buy a surplus parachute that I use to partition the bus or for privacy as needed. I can still use my roof hatch.
You could make a hole between any ribs throughout the bus to make into a skylight. It's just sheet metal. Cut the hole, frame it with steel and install the plexiglass the same as you would if you were using the roof hatch.
Robin
Nobody's Business
02-06-2018, 05:17 PM
I'm not sure if I conveyed my thought clearly. I already have an existing roof hatch which either is beginning to leak, or is likely to soon. Before that happens, I want to remove the original one. I could rather easily replace it with flat lexan and I wouldn't need to ask if this was what I planned.
I want a skylight designed to open and close, which can still serve as an emergency exit if needed. Preferably something with a low profile.
02-06-2018, 05:20 PM
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
There is a User here, I forget his name??? He just installed a real nice boat hatch, looked like exactly what you need. He got if off ebay, had trouble finding right screws....
02-06-2018, 05:22 PM
Traveling
Rated Cap: '00
02-06-2018, 05:49 PM
They are flat, but not exactly a skylight.
I drive on brushy roads so the low profile marine hatch would work well.
Robin
Nobody's Business
02-06-2018, 08:24 PM
Year: 1987
Hey! That was me
I was trying to read more about leaking windows and ended up here.
I just replaced my emergency hatches with a plug and play skylight option that still allows roof access: a boat hatch. They are expensive but after a couple sessions scouring the web I found some good options for me. Even found some that could be custom made on alibaba.com I'm really happy with them. BTW they DO lock from the inside (or at least mine do. make sure yours will too!!)
Rusty linked to the one I bought above.
One thing to note: your hatch is fiberglass I suppose which bends a bit and these are typically a rigid metal so you need a flat or almost surface. My bus happened to have that, but yours might not.
Yes I'm still pondering what screws to use. My SS screws recommended by the manufacturer sheered off or broke off, what a mess.
I will upload a youtube video about the install in the following days which will show up on my build thread: http://www.skoolie.net/forums/f11/gi...n-20183-7.html
