Originally Posted by sojourner
I removed both hatches (cracked and beyond repair) and used 17ga galvanized sheet metal to cover the opening and previous mounting holes. Drilled, sealed and riveted in place.
Nice.
I did the same, using 16g galvanneal 28.5" X 30". One with a 14 -3/16" sq hole. Dynatron/SS rivets
(Note the white plastic barrel inside the bus, ha.)
I bridged the ribs & centered the rivets with both hat channels.
Documented, here:
https://www.skoolie.net/forums/membe...+ac-page2.html
The white on the roof is not paint. I only cleaned the work area of dirt & pollen. (Small amount of primer, under the patch.)
